Pocket GPS World :: View topic - Creating data sections same coverage as OS Landranger maps
Privateer
PostPosted: Thu Jul 15, 2004 1:46 pm    Post subject: Creating data sections same coverage as OS Landranger maps Reply with quote
I have recently bought MM2004 OS edition for the whole of GB (1:50,000), so I’m very much a beginner on this topic. Wink
In the next few weeks we're hoping to go on a car rally / Treasure hunt that requires Ordnance Survey Landranger (1:50,000) paper map number 141 Kettering and Corby. I already have a paper map of the area, and the rules allow electronic maps and GPS equipment to be used as well. Thumbs Up
Is there a way of transferring a piece of map data from the PC to the PDA that is the same size and area as covered in the paper map 141?
Thanks,
Robert.
Garmin Camper 770 LMT-D
MrT
PostPosted: Thu Jul 15, 2004 4:12 pm    Post subject: Reply with quote
Just zoom and resize your window on the PC to cover the area you want then export the visible region to the PDA.
Privateer
PostPosted: Thu Jul 15, 2004 4:32 pm    Post subject: Reply with quote
Hi MrT,
Thanks for the reply. Thumbs Up
In this case I have the paper map so that is relatively easy to find the area. What happens if the area covers more than one region, will Memory-Map automatically stitch the regions together for one area that can be exported to the PDA?
I take it that there is no lazy way of specify map 141, which instructs Memory-Map to export that area (covered by the paper map) to the PDA?
Robert.
MrT
PostPosted: Sat Aug 07, 2004 8:05 am    Post subject: Reply with quote
There is usually quite an overlap on map regions (except aerial photography) so this is usually not necessary. However if a route does cover a boundary, you need to merge the maps together on the PC, view the merged map, then export the area you want to the PDA.
22.043 (17 Apr 24)
