T5YOB Lifetime Member
Posted: Sun Jul 12, 2020 6:41 pm Post subject: |
I've tried playing around with this, but I can't get past the part of unzipping the database on the app thing it just keeps saying the following Picture and Sound CSV files couldn't be found.
I've tried following the instructions but I'm not too clued up with this sort of stuff, what I'm doing wrong probably is something really simple for you guys and you're probably thinking what a "retard" .
I want to try and get it working though as I like how you can change what info it displays in the warning banner when the alerts pop up. Any help appreciated,
Cheers. |
dales Frequent Visitor
Joined: May 04, 2008 Posts: 752 Location: Knaresborough, North Yorkshire.
Posted: Sun Jul 12, 2020 10:20 pm Post subject: |
You are trying the CSV to GPX Converter, yes ??
If so, have you linked the Converter to your Working Folder (where you keep your camera files and voice warning files etc) ? This needs to be done.
In the Converter, press Program Options, and then Working Folder.
Now you can navigate to the folder where your camera files etc are filed.
Select it, press OK, and you should be on your way. _________________ nuvi 2599LMT-D, oregon 700, basecamp, memory-map. |
Kremmen Pocket GPS Verifier
Posted: Mon Jul 13, 2020 5:17 am Post subject: |
Once you have unzipped the package you will see this:
The help files are marked in red. Choose any one, they are all identical in content. Everything is explained in detail in there.
_________________ Satnav:
Car Average MPG :
Posted: Mon Jul 13, 2020 2:33 pm Post subject: |
I managed to get all the blocks green after unzipping the relevant files and had a play around with the alerts distances, I take it the time in seconds is how many seconds it warns you before you hit the cam, ie if you set it to 10 seconds it warns you when you are 10 seconds off going past the camera?
Also I changed the banner display writing pressed save and it saved it but after processing them and uploading them to my unit the banner writing is still the same as before? What have I done wrong? |
Posted: Mon Jul 13, 2020 2:49 pm Post subject: |
Hmmm, it should have performed the text change on processing.
Open the first .gpx file, which should be 'gatso_fifty.gpx' (Notepad will do to open it)
In my gatso_fifty the first camera name is SE-GATSO:46#50, third line down.
If yours is the same then it hasn't performed the change.
I won't delve any further till you reply. _________________ Satnav:
Car Average MPG :
Posted: Mon Jul 13, 2020 7:27 pm Post subject: |
Kremmen wrote: | Hmmm, it should have performed the text change on processing.
I won't delve any further till you reply. |
Just had a look and it says "SE-GATSO:46#50" |
Posted: Tue Jul 14, 2020 4:38 am Post subject: |
The text change can only happen after you have processed the CSV to GPX as it needs a 'known' base to work from.
So the sequence is:
Download the database (if not already done)
Run the main CSV to GPX 'Process'
Then go to the Text Change screen and it should show 'Unlocked' and the blue boxes will show the alert text selected. Adjust as required.
Note: for a Garmin leave the @50 or the Garmin won't know what speed to alert you.
Once sorted, run the 'Process' from that screen and it will 'change' the text.
Text before change:
Text after change:
Car Average MPG :
Posted: Tue Jul 14, 2020 1:12 pm Post subject: |
This is where I am struggling, I've got the app up and all 3 rows are green as they should be but when I try to change the Banner text mine is still saying LOCKED in red??
I have no idea where I am going wrong tbh.[/img] |
Posted: Tue Jul 14, 2020 1:40 pm Post subject: |
Did you read my post above?
After you run the main Process ...... you then go to the text change screen before using POILoader _________________ Satnav:
Car Average MPG :
Posted: Tue Jul 14, 2020 2:29 pm Post subject: |
Yes sorry, I didn't read it properly, problem solved thank you. :-). Does this process need to be done with every update? |
M8TJT The Other Tired Old Man
Posted: Tue Jul 14, 2020 4:10 pm Post subject: |
No. It sticks. |
Posted: Tue Jul 14, 2020 4:24 pm Post subject: |
It does
What you have set in the text change screen will stay put.
However ..... after you have run the main process don't go straight to POILoader but to the text change screen and run that 'Process' as well.
I did try and work round it a bit more elegantly but each new PGPSW download builds the PGPSW default camera ID's, example NW-Gatso9999@50. What the text change does is find and replace text withing the .GPX files.
So don't 'Finish & Launch POILOader' but just 'Finish'. Then go to 'Text Change' then go to POILoader. _________________ Satnav:
Car Average MPG :
Posted: Tue Jul 14, 2020 8:43 pm Post subject: |
Ok thanks will bare that in mind for next time, I believe the databases are updated every Wednesday if I read some previous posts on the forum right?
Btw really appreciate all your help with doing this, sorry for being a pain with it all , bit confusing the 1st time not having done anything like it before. |
Posted: Wed Jul 15, 2020 4:07 am Post subject: |
It's like a lot of things, once you've got it working the first time, each weekly update is a breeze.
I don't change the text as I just rely on the spoken warnings, they are all I need as an alert. Hence why I had to look up the text change procedure.
With regard to the weekly update, the program, when loaded, will tell you when a newer database is available. _________________ Satnav:
Car Average MPG :
Posted: Wed Jul 15, 2020 2:49 pm Post subject: |
Kremmen wrote: |
Yes this is the main reason I wanted the PocketGPSdatabase on my nav for the spoken alerts also. |
