Pocket GPS World :: View topic - 51LMT-S charging
51LMT-S charging
bermec
PostPosted: Thu Jan 10, 2019 7:35 pm    Post subject: 51LMT-S charging Reply with quote
New member, hi all, hoping I am posting in the correct sub-forum.
I have a 51lmt-s that never seems to fully charge.
Each time I switch on without a charging lead I get a low-battery warning, even after leaving it on overnight charging.
I have now left it plugged in but switched off, but have no idea if it is charging. Time will tell I suppose.
I am using the adapter supplied with it.
Any info gratefully received,
bermec.
PostPosted: Thu Jan 10, 2019 7:41 pm    Post subject: Reply with quote
Well Garmin devices these days won't last long on battery but what you describe isn't normal. When you say you've left it overnight on charge, what is charging it?
bermec
PostPosted: Thu Jan 10, 2019 8:59 pm    Post subject: charging Reply with quote
It was left overnight switched on charging from a mains charger which should outperform the 1amp 5volt vehicle charger.
I have no ides of the power consumption of the unit.
btw Thanks for replying.
PostPosted: Thu Jan 10, 2019 9:50 pm    Post subject: Reply with quote
That's strange then. A wall charger should fully power your device. My 50 has a battery icon top right, if your 51 does what does it show when you switch it on after overnight charging? I'd also try switching it off fully rather than leaving it on while charging.
bermec
PostPosted: Thu Jan 10, 2019 10:22 pm    Post subject: Reply with quote
After overnight charging the indicator shows about 50% then slowly falls and the 'low battery' warning appears.
I plugged the unit in in the car 2 -3 hours ago which automatically switches the unit on then switched it off.
Still the same result when checked 10 minutes ago.
The indicator does show a charging symbol when plugged in.
Doing a software update...
Update done, still don't know if it charges switched off so turned brightness to minimum and leaving overnight.
Thanks for the feedback, if this fails will send the unit back.
Checked this morning, now have a fully charged unit, well pleased.
always best to install updates! Smile
Thanks Susamb.
22.044 (24 Apr 24)
