entwood Regular Visitor
DennisN Tired Old Man
Posted: Sat Mar 10, 2018 9:13 am Post subject: |
Aaargh!
I need Mac fixing instructions please. _________________ Dennis
Two of them are obesiting!! |
dhn Frequent Visitor
Joined: Oct 08, 2007 Posts: 2544 Location: Toronto CANADA
Posted: Sat Mar 10, 2018 12:12 pm Post subject: |
Dennis, I would think that just using Finder instead of Windows Explorer and using Mac's version of a text editor would do the job. _________________ David |
Posted: Sat Mar 10, 2018 7:55 pm Post subject: |
Yes indeed it will, David. Text editor is fine, but I can't find this file with Finder
Navigate to: C:\Program Files\TomTom HOME 2\xul
Using Notepad, Wordpad or another text editor, edit the file in xul called application.ini _________________ Dennis
smarty5927 Lifetime Member
Posted: Sun Mar 11, 2018 11:44 am Post subject: |
On a MAC, navigate to :
Users/USERNAME/Library/Application Support/TomTom
There should be a HOME directory of some sort in there and I suspect the file you are looking for will be somewhere in that area.
John |
Posted: Mon Mar 12, 2018 10:36 am Post subject: |
That doesn't work for me either, I'm afraid. I have....
Users/myname/ - nothing in there about library, only the folders I've created myself.
Users/Shared/Library/Application Support/Adobe and that's all that's in there. _________________ Dennis
justbrowsing Frequent Visitor
Posted: Mon Mar 12, 2018 10:50 am Post subject: |
Like Windows, do you have a "show hidden files & folders" option? |
Posted: Mon Mar 12, 2018 12:03 pm Post subject: |
Sounds a bit like a permissions thing.
Open System Preferences, select Users and Groups and it should give a list of the users and their Role.
In my case my username is set with the Admin role, so if your username isn't set to Admin role then you will probably need to login using one of the Admin accounts.
John |
Posted: Mon Mar 12, 2018 9:13 pm Post subject: |
Well, some progress - nottalot, but some!
I was already Administrator.
By pure chance, I clicked on summat and it offered "Show Library", so I did and it did.
So.... Users/USERNAME/Library/Application Support/TomTom
OK. In that I have two folders, HOME3 and MyDrive Connect
In HOME3, there are two .ini files
cookies.ini - to my ignorant brain, contents are referring to cookies.
prefs.ini - One of the many lines reads "Name=TomTom MyDrive Connect support application", so I can't think it has anything to do with Home.
The MyDrive Connect folder contains nothing relating .ini.
Still flopping around all over the place, I have another folder under Apoplication Support called TomTom HOME
So I have /tomtom Home/Profiles/r8x2yesv.default/compatibility.ini which reads.....
[Compatibility]
LastVersion=2.10.3.700_8122017_1406/20090605134702
LastOSABI=Darwin_x86-gcc3
LastPlatformDir=/Applications/TomTom HOME.app/Contents/Frameworks/XUL.framework
LastAppDir=/Applications/TomTom HOME.app/Contents/Resources
What does anybody think about this being the one to alter?
My current inclination is to download (and install?) the version linked above, then, without opening it, to look at the compatibility.ini file above to see if it has changed. _________________ Dennis
Posted: Mon Mar 12, 2018 9:21 pm Post subject: |
Dennis,, I know nowt about Mac's at all (except to wear them when its raining .. ) but the instructions for windows say
After running the *.exe to install the version of TTHome, do NOT run it.
Using Notepad, Wordpad or another text editor, edit the file in xul called application.ini as follows:
In the line which reads 'Version=2.X.X.XXXX' (matching the version you have just installed), modify the number to read '3.x.x.xxxx' (I left the other numbers, just changed the leading one to "3". Once saved just run TTHome as usual, it will all work just fine
I guess the same would apply to Mac OS except that, as you've found, the file location is different ...., also .. I have no such file as "compatability.ini" anywhere in windows ...... |
Posted: Mon Mar 12, 2018 9:28 pm Post subject: |
Thank you. My concern is that the compatibility file I found may just be an information file, not the true configuration file and editing it may do nothing useful. I shall try it if nobody else come on with true knowledge before the next occasion I have time available to mess around with it.
PS What I know about Macs is also nowt, except that they just work and don't fall over like the windoze stuff which plagued me for more than 20 years until I got the sense to switch over. _________________ Dennis
M8TJT The Other Tired Old Man
Posted: Tue Mar 13, 2018 12:19 am Post subject: |
And open a brand new can of worms for yourself. |
Posted: Wed Apr 11, 2018 8:48 pm Post subject: |
So the next map is about to be released - that’s why Renault have just released map v1000. #bluddyGRRR! _________________ Dennis
Posted: Wed Apr 11, 2018 9:13 pm Post subject: |
Mid/end May for the next v1010 maps I'm guessing |
