druck Regular Visitor
Joined: Dec 19, 2003 Posts: 96 Location: Surrey, England
Posted: Sun May 21, 2017 7:08 pm Post subject: |
Darren wrote: | I've compared the AlcoSense to an alcometer to show it is broadly accurate. So why would having someone run tests the morning after demonstrate that this is any more effective at measuring BAC? |
Well the reason is although we know the test is done on blood alcohol levels, and is exactly the same test the morning after as on the night of the drinking, the human experience at each time is quite different.
We all know what it feels like to have had a few drinks and to no longer be safe to drive, but it doesn't feel the same the morning after, you may well have no apparent symptoms. Therefore it would be reassuring to know that the tests correctly detected that you weren't safe to drive, even if you felt fine.
M8TJT The Other Tired Old Man
Posted: Sun May 21, 2017 7:38 pm Post subject: |
druck wrote: | Well the reason is although we know the test is done on blood alcohol levels, and is exactly the test same the morning after as on the night of the drinking,. | ??? What? I don't think so. |
Posted: Mon May 22, 2017 9:55 am Post subject: |
M8TJT wrote: | druck wrote: | Well the reason is although we know the test is done on blood alcohol levels, and is exactly the test same the morning after as on the night of the drinking,. | ??? What? I don't think so. |
Sorry mistyped, it should read; Well the reason is although we know the test is done on blood alcohol levels, and is exactly the same test the morning after as on the night of the drinking.
Posted: Mon May 22, 2017 3:53 pm Post subject: |
willmow Regular Visitor
Posted: Fri Jun 02, 2017 9:00 pm Post subject: |
Interesting stuff. I've always wondered what 2-3 pints of ale gives. I might suggest my local gets one of these.
In terms of metrics, I found this:
Unit of measurement currently used in the United Kingdom, Ireland, Cyprus and Singapore: micrograms of alcohol per one hundred millilitres of breath
Usually abbreviated as – µg/100ml [or µg/100mL, or µg/%]
A typical format for a measurement result expressed in this unit is 35, with the likely range being from 0 to 200 _________________ Where there's a will - there's me! |
DennisN Tired Old Man
Posted: Sat Jun 03, 2017 8:21 am Post subject: |
Has it been upgraded to work with the latest iOS? _________________ Dennis
Two of them are obesiting!! |
