mikeshe Lifetime Member
Posted: Sat Feb 13, 2016 2:02 am Post subject: Tomtom 730 Reboots? |
I have a TT730 which works perfectly until it has to re-plan a route because I have chosen not to take a suggested turning.
It starts to re-plan and then it reboots. It may do this once or a few times before navigating a revised route.
Has anybody any ideas why it might be doing this and how to solve it?
TIA. |
justbrowsing Frequent Visitor
Posted: Sat Feb 13, 2016 10:09 am Post subject: |
May just need to run clearflash.exe 3 times? |
Posted: Sun Feb 14, 2016 1:53 pm Post subject: |
Thanks.
I've run clearflash 3 times... will give it a try over the next week to see how it goes.
I use a Truck Map with this model, is it possible to copy all the internal memory and the truck map onto an SD card so it runs from the card? |
Posted: Sun Feb 14, 2016 4:51 pm Post subject: |
mikeshe wrote: | Thanks.
Yes you can, or just copy the map folder to the card as these don't need the map AND navcore/application together. You could even delete everything off the internal memory if you wanted to and run it alll from the card. |
Posted: Sun Feb 14, 2016 5:17 pm Post subject: |
Ok, thanks. |
