Pocket GPS World :: View topic - CN EU 2016.30 NTU
CN EU 2016.30 NTU
Goto page 1, 2, 3  Next
PostPosted: Sat Nov 07, 2015 8:15 pm    Post subject: CN EU 2016.30 NTU Reply with quote
Crikey, the manifest for CN EU 2016.30 is already on Garmin servers, was only a few weeks ago we got 2016.20. However given Garmin's recent delays in releasing the maps I wouldn't hold your breath, while in the past a map update used to be released within a week or so of hitting the servers, recently it's been a month or so.
Interestingly the manifest refers to an 'Experimental gmap', not seen that before!
PostPosted: Sun Nov 08, 2015 6:38 am    Post subject: Reply with quote
Sounds like someone has uploaded the test map to the wrong place.
Satnav:
Car Average MPG :
Roy124
PostPosted: Mon Nov 09, 2015 9:06 pm    Post subject: Reply with quote
@sussamb
Can we have that in English please Smile?
I can work out EU but CN?
What does it mean on the Servers but no released?
PostPosted: Mon Nov 09, 2015 10:01 pm    Post subject: Reply with quote
CN is City Navigator. It's what Garmin call their maps.
On the servers mean the basic code necessary is there but you can't yet access the maps.
Roy124
PostPosted: Mon Nov 09, 2015 11:03 pm    Post subject: Reply with quote
Thank you
BAVC10
PostPosted: Thu Jan 07, 2016 12:23 am    Post subject: Reply with quote
Now available for download from Garmin Express
DriveLuxe 51 LMT D - Firmware 6.70
Previously owned: DriveLuxe 50 LMT-D, NuviCam LMT-D, Nuvi 3598 LMT-D, Nuvi 3490LMT, 3790T, 1690, 765, 760, 660, 610, 360, 310, 300 and Streetpilot i3
BigJohnD
PostPosted: Fri Jan 08, 2016 1:57 am    Post subject: Reply with quote
Now updated, thanks.
Took a lot less time than the predicted 2 hours, probably a fraction over an hour.
PostPosted: Fri Jan 08, 2016 7:51 am    Post subject: Reply with quote
Mine too ... Wink
PostPosted: Fri Jan 08, 2016 8:13 am    Post subject: Reply with quote
I did the software update yesterday then within the hour got the map update prompt (after the unit was back in the car)
typical Rolling Eyes
Satnav:
Car Average MPG :
PostPosted: Fri Jan 08, 2016 10:48 am    Post subject: Reply with quote
2599 done, but GE is still not stable.
After it downloaded, prepared, built then copied the maps, it went loopy and the progressbar was flickering and the time remaining was flashing from 10 to 20 hours and times in between.
I just left it alone and after about 10 minutes it changed to completed.
Not the first time it's done similar.
Satnav:
Car Average MPG :
PostPosted: Fri Jan 08, 2016 11:05 am    Post subject: Reply with quote
I've seen similar, I think the fact the download is substantial means that any change in download speeds has a significant impact on 'predicted download time'. I just ignore it and let it get on with it.
PostPosted: Fri Jan 08, 2016 2:03 pm    Post subject: Reply with quote
This was after the download stage.
It went through all the various steps correctly and had got down to about 7 minutes left when it went loopy (techy term)
Still, it worked in the end.
Satnav:
Car Average MPG :
PostPosted: Fri Jan 08, 2016 3:14 pm    Post subject: Reply with quote
Guess that's the main thing Wink
PostPosted: Fri Jan 08, 2016 3:53 pm    Post subject: Reply with quote
I did the 2597 yesterday without a hitch.
One other thing - the 2597 caused a download, which as we've found was saved.
The 2599 update recognised the download so stage 1 went straight to 50% and then carried on from there.
Strange as I thought the map sets were different. Therefore Watson, I guess the downloads are identical but the processing stage does different things for different models?
Satnav:
Car Average MPG :
PostPosted: Fri Jan 08, 2016 5:30 pm    Post subject: Reply with quote
Map is the same, as you surmise Express just creates the part for your device that you're entitled to.
Incidentally if you choose to download to your PC as well as device you should get the full map you're entitled to on your PC for Basecamp to use even if you only download a subset to your satnav.
Page 1 of 3
22.034 (27 Mar 24)
