sussamb Pocket GPS Verifier
Joined: Mar 18, 2011 Posts: 4454 Location: West Sussex
Posted: Sat Nov 07, 2015 8:15 pm Post subject: CN EU 2016.30 NTU |
Crikey, the manifest for CN EU 2016.30 is already on Garmin servers, was only a few weeks ago we got 2016.20. However given Garmin's recent delays in releasing the maps I wouldn't hold your breath, while in the past a map update used to be released within a week or so of hitting the servers, recently it's been a month or so.
Interestingly the manifest refers to an 'Experimental gmap', not seen that before! _________________ Where there's a will ... there's a way. |
Kremmen Pocket GPS Verifier
Posted: Sun Nov 08, 2015 6:38 am Post subject: |
Sounds like someone has uploaded the test map to the wrong place. _________________ Satnav:
Car Average MPG :
Roy124 Regular Visitor
Posted: Mon Nov 09, 2015 9:06 pm Post subject: |
@sussamb
Can we have that in English please ?
I can work out EU but CN?
What does it mean on the Servers but no released? |
Posted: Mon Nov 09, 2015 10:01 pm Post subject: |
CN is City Navigator. It's what Garmin call their maps.
On the servers mean the basic code necessary is there but you can't yet access the maps. _________________ Where there's a will ... there's a way. |
Posted: Mon Nov 09, 2015 11:03 pm Post subject: |
Thank you |
BAVC10 Lifetime Member
Posted: Thu Jan 07, 2016 12:23 am Post subject: |
Now available for download from Garmin Express _________________ DriveLuxe 51 LMT D - Firmware 6.70
Previously owned: DriveLuxe 50 LMT-D, NuviCam LMT-D, Nuvi 3598 LMT-D, Nuvi 3490LMT, 3790T, 1690, 765, 760, 660, 610, 360, 310, 300 and Streetpilot i3 |
BigJohnD Frequent Visitor
Joined: Aug 26, 2007 Posts: 391 Location: Glannau Mersi, Lloegr
Posted: Fri Jan 08, 2016 1:57 am Post subject: |
Now updated, thanks.
Took a lot less time than the predicted 2 hours, probably a fraction over an hour. |
Posted: Fri Jan 08, 2016 7:51 am Post subject: |
Mine too ... _________________ Where there's a will ... there's a way. |
Posted: Fri Jan 08, 2016 8:13 am Post subject: |
I did the software update yesterday then within the hour got the map update prompt (after the unit was back in the car)
typical _________________ Satnav:
Car Average MPG :
Posted: Fri Jan 08, 2016 10:48 am Post subject: |
2599 done, but GE is still not stable.
After it downloaded, prepared, built then copied the maps, it went loopy and the progressbar was flickering and the time remaining was flashing from 10 to 20 hours and times in between.
I just left it alone and after about 10 minutes it changed to completed.
Not the first time it's done similar. _________________ Satnav:
Car Average MPG :
Posted: Fri Jan 08, 2016 11:05 am Post subject: |
I've seen similar, I think the fact the download is substantial means that any change in download speeds has a significant impact on 'predicted download time'. I just ignore it and let it get on with it. _________________ Where there's a will ... there's a way. |
Posted: Fri Jan 08, 2016 2:03 pm Post subject: |
This was after the download stage.
It went through all the various steps correctly and had got down to about 7 minutes left when it went loopy (techy term)
Still, it worked in the end. _________________ Satnav:
Car Average MPG :
Posted: Fri Jan 08, 2016 3:14 pm Post subject: |
Kremmen wrote: |
Still, it worked in the end. |
Guess that's the main thing _________________ Where there's a will ... there's a way. |
Posted: Fri Jan 08, 2016 3:53 pm Post subject: |
I did the 2597 yesterday without a hitch.
One other thing - the 2597 caused a download, which as we've found was saved.
The 2599 update recognised the download so stage 1 went straight to 50% and then carried on from there.
Strange as I thought the map sets were different. Therefore Watson, I guess the downloads are identical but the processing stage does different things for different models? _________________ Satnav:
Car Average MPG :
Posted: Fri Jan 08, 2016 5:30 pm Post subject: |
Map is the same, as you surmise Express just creates the part for your device that you're entitled to.
Incidentally if you choose to download to your PC as well as device you should get the full map you're entitled to on your PC for Basecamp to use even if you only download a subset to your satnav. _________________ Where there's a will ... there's a way. |
