Pocket GPS World :: View topic - Battery problems solved
ChrisJakarta
PostPosted: Thu Sep 25, 2014 8:35 am    Post subject: Battery problems solved Reply with quote
Satmap recently posted the following on their Facebook page:
Is your battery dying quickly? See if this fixes it for you!
See https://satmap.com/knowledge/Active_12/Battery_Issues.html
This was very timely information for me. After a couple of hours use, the battery indicator on my -10 was periodically showing a red bar, then reverting to three greens, then going red again. I assumed a battery problem and was about to order a new one. But I thought I should try doing a settings reset see https://satmap.com/knowledge/Active_12/Defaulting_Settings.html. And it solved the problem!
I also suggest recording all the settings before the reset; I keep a file of all settings. With this, it is much easier to return to previous preferences. And don't forget that the Active Route Colour will be reset to a quite solid blue. To change this to something less intrusive, the setting is a bit hidden: Routes Menu | Select any route | Edit | Edit Active Route Colour | Edit then select your choice and click Set. Not sure why this is not in the Settings, since it affects all routes.
Chris
20.114 (23 Nov 22)
Terms & Privacy
