Pocket GPS World :: View topic - Road Angel Classic: Database PC Software tip
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Hardware based GPS SCD Systems
martin99
PostPosted: Fri Sep 10, 2004 10:55 pm    Post subject: Road Angel Classic: Database PC Software tip Reply with quote
When updating the classic RA with the serial data cable and V1.7.UK PC software be sure to set the GPS data off AND THEN press the RA Store key to return the RA display to the idle state which is "---mph".(The RA manual dosn`t mention the "store" bit, just turn off the GPS in the GPS menu by pressing delete key).
I kept getting "unit not found check settings" error on the PC prog window until I did this. I knew I had set the correct com port option on the PC prog; I proved this by toggling the RA GPS signal on/off on the RA by pressing the RA "delete" function key when in the RA GPS menu .The GPS Data-On state gives a positive indication by way of giving "buffer overflow/time out" errors in the PC prog window ( expected as the PC prog is not supposed to make sense of this,but it proved the data line and the com port were working).
Hope this stops others thinking they`ve got a duff serial port. Smile
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Hardware based GPS SCD Systems All times are GMT + 1 Hour
22.034 (27 Mar 24)
