Pocket GPS World :: View topic - How to get my original uk map back.
scoobimax
PostPosted: Fri Aug 24, 2012 1:05 am    Post subject: How to get my original uk map back. Reply with quote
During my uploading a newly purchased central europe map, my one XL unit crashed and had to be re-formatted.
When the download completed my unit no longer has my UK & Ireland map and I can't find them on my laptop anywhere..
How do I get the originally supplied UK & Ireland map back - any ideas?
Thanks,
Max
dhn
PostPosted: Fri Aug 24, 2012 1:32 am    Post subject: Reply with quote
Was your UK & ROI the original or an update on your device? If it was an update, you should be able to find it in compressed format here:
C:\Documents and Settings\yourname\My Documents\TomTom\HOME\Downloads\complete\maps\ and you can reinstall maanually.
See here:
http://www.tomtomforums.com/t18197-how-install-downloaded-map-without-using-home.html
Also, connect your device to Home. Manage my Unit (2nd page)--Items on Computer--Maps. What does it show there?
scoobimax
PostPosted: Fri Aug 24, 2012 12:07 pm    Post subject: Reply with quote
See here:
Thanks for the advice.
The UK & Ireland map was the original on the unit, and I cannot find it anywhere on my laptop.
Also, when in the manage my unit in TomTom Home, under the maps section is only the central Europe map - no UK. Thats the first place I looked when I realised it was missing of my unit.
dhn
PostPosted: Fri Aug 24, 2012 12:28 pm    Post subject: Reply with quote
Without a backup, I'm afraid you are out of luck..........
scoobimax
PostPosted: Fri Aug 24, 2012 1:29 pm    Post subject: Reply with quote
Sorted - I found a folder on my laptop called UK & Ireland dating back to 2009.
I've manually copied that tommy device outside of TomTom home and I now have both UK & Ireland and central Europe maps on my device.
About to back up via home too so all seems sweet.
Thanks for the help - it pointed me in the direction of finding the original uk map.
Max
dhn
PostPosted: Fri Aug 24, 2012 1:37 pm    Post subject: Reply with quote
May I suggest you do NOT do the backups using Home but, rather, use Explorer. See here:
http://www.tomtomforums.com/t17864-how-backup-contents-your-unit-computer-how-restore.html
scoobimax
PostPosted: Fri Aug 24, 2012 2:04 pm    Post subject: Reply with quote
Thanks. In the process of a manual back up as described in above link. Once done will check for updates and then repeat above in a sub folder.
Max
22.043 (17 Apr 24)
