Pocket GPS World :: View topic - CP5 Live Service
CP5 Live Service
Goto page Previous  1, 2, 3
PostPosted: Thu Sep 02, 2004 8:10 pm    Post subject: Reply with quote
AFAIK and I may be wrong here, but I didn't think it was down to the application to disconnect the connection. Once the connection is open it's like a broadband connection. It's open constantly until you manually close it or if an application thinks it's using a dial-up connection and tries to disconnect the connectoid. The only way it should disconnect is if you manually disconnect the call or if an application isn't GPRS aware. I don't think CoPilot or other apps will be trickle sending data to keep the connection live.
Certainly when I establish a connection on my 2210 the connection stays open until I lose GPRS coverage (drops to 1 bar) or I terminate it.
HielandLad
PostPosted: Fri Sep 03, 2004 4:41 pm    Post subject: Reply with quote
I've just set up the live function in anticipation of the traffic update. I can confirm that CP5 does keep the connection open. You can then choose how often it actually sends updated position information to the live server.
Hope this helps.
PS Any update on when we are likely to see the traffic bit?
Page 3 of 3
22.043 (17 Apr 24)
