TheMidnightRambler Occasional Visitor
Posted: Thu Mar 01, 2012 8:01 am Post subject: |
Many thanks. You've all ben really helpful. I'll post back the final outcome soon. |
FrequentFlyer Lifetime Member
Posted: Sun Mar 04, 2012 2:24 pm Post subject: |
LostMike wrote: | Not sure what you have finally decided to do MidnightRambler but I thought I would add a postscript based on a walk I went on today. The lady who led it encountered a locked gate and a stalwart landowner who declined to open it. This meant she had to re-plan the walk on the fly. It then turned out that some nearby footpaths were not in good order. She was quite lost (literally) but with the A10 hanging on my shoulder I could advise her exactly where she was and where the nearest legal path was. After a few false starts we got back on track and all was well. However without the A10 to show her where she really was on a map that showed the legal footpaths (I think this only applies to OS maps) we would have had a far more difficult time.
I thought that this was a pretty good example of why I think the A10 is so good. I acknowledge that ViewRanger on a smartphone or similar has similar attributes but I don't find this as rugged or quite as well designed for use in the field. |
Not a very good leader to be totally 'Lost'....amazing, was this a formally organised walk by Ramblers....if so, a complaint would be the order of the day. |
mikeiow Occasional Visitor
Posted: Mon Apr 30, 2012 10:19 am Post subject: |
Maybe it is or the unit I saw, but the display looks *incredibly* washed out on the Active 10 unit. For example, I could not really see the contour lines clearly at all once at the 1:25K level.
Very very weird.
Kind of makes me think it is not such a useful tool as I had hoped.
Anyone else think that ?
cheers
Mike
Have deleted duplicate post from other thread to keep both neat. GerryC (mod) |
rothers Regular Visitor
Posted: Mon Apr 30, 2012 11:33 am Post subject: |
mikeiow wrote: |
Maybe it is or the unit I saw, but the display looks *incredibly* washed out on the Active 10 unit. For example, I could not really see the contour lines clearly at all once at the 1:25K level. |
Sounds like you had the sun filter turned on (which removes fine detail to make major features more readable in strong sunlight). |
Posted: Mon Apr 30, 2012 11:58 am Post subject: |
thanks, yes, that does make things less of a problem: however, it is still not as bright/clear (even if I set to 100% brightness) as I would expect. Perhaps spoiled by more modern style phones/iPad displays :-(
Wonder if they are planning to refresh the screen tech.... |
sussamb Pocket GPS Verifier
Joined: Mar 18, 2011 Posts: 4456 Location: West Sussex
Posted: Mon Apr 30, 2012 1:46 pm Post subject: |
Maybe ... the Etrex 20/30 screen is a delight to use, readable through bright sunlight to dull light |
Andy_P Pocket GPS Moderator
Posted: Mon Apr 30, 2012 4:22 pm Post subject: |
... and hopefully in the dark too! _________________ "Settling in nicely" ;-) |
WalkerDan Occasional Visitor
Posted: Mon Apr 30, 2012 4:29 pm Post subject: |
Never had a problem viewing the screen and its details. Ref: Etrex 20/30 - had a look at these once and the screen may be clear to see but it's only the size of a postage stamp and far too small to be of much use despite what others may say. Even though I have had a Satmap for a couple of years and it may be due an update if I was buying today it would still be a Satmap, especially with some of the deals available that include maps. |
Andy_P wrote: | ... and hopefully in the dark too! |
Oh yes ... at least with the backlight on |
Posted: Mon Apr 30, 2012 4:35 pm Post subject: |
WalkerDan wrote: | Ref: Etrex 20/30 - had a look at these once and the screen may be clear to see but it's only the size of a postage stamp and far too small to be of much use despite what others may say. |
Quite a bit bigger than a postage stamp, although I accept not as large as some, including Satmap. Not sure what you mean though by 'too small to be of much use'. I use mine for caching and hiking and it's ample big enough, so much so that my map stays in my rucksack these days, only there in case I lose my GPS |
AlanMather Occasional Visitor
Posted: Thu May 03, 2012 9:55 pm Post subject: |
Someone asked about route planning for Satmap.
Xpedition is very good.
I also like www.bikehike.co.uk This is free and the elevation data is retained on route exports to your Satmap using SatSYNC software from Satmap. |
