Pocket GPS World :: View topic - Navigon on iPhone
Navigon on iPhone
Bazjaco
PostPosted: Mon Jan 16, 2012 8:37 pm    Post subject: Navigon on iPhone Reply with quote
The volume on the app is set to maximum and the volume on the phone is set to maximum but the volume is still difficult to hear. Any suggestions as to how to increase the volume or is there a way to route the volume through the car speakers using Bluetooth?
Cool
Regards
PostPosted: Mon Jan 16, 2012 9:05 pm    Post subject: Reply with quote
Is your equipped with Bluetooth that supports the A2DP profile, if it does then you should be able to send the audio from the nav app to the car.
If you are thinking about adding BT capability to your car have a look at the iO-Play or Parrot MKi9100, whatever you get make sure it has A2DP support or it won't work with the iPhone correctly - Mike
Tobas
PostPosted: Sun Feb 05, 2012 5:06 pm    Post subject: Reply with quote
I find the volume dodgy but once you sort it out, it's quite loud. Here's what I do; use the iphone buttons to lower the volume right down then back to nearly full volume. Go into the app, go to the volume control and slide it to the left then to the right. That always fixes it for me, good luck!
It seems to be affected by other volume changes that shouldn't really affect the app but they do.
22.034 (27 Mar 24)
