Pocket GPS World :: View topic - Ash10's Camera Manager Software
Goto page Previous  1, 2, 3 ... 66, 67, 68 ... 75, 76, 77  Next
Ash10
PostPosted: Tue Aug 23, 2011 7:21 pm    Post subject: Reply with quote
Camera Manager v3.6 beta now available
This fixes a bug with the automatic creation of certain voice warnings for alert speeds greater than 100 (kph).
Also fixes the issue with missing downloaded zip files (ie: if they have been inadvertently deleted from the POI directory, or new database regions have just been selected).
Download link below (same as before).
westcatford
PostPosted: Thu Aug 25, 2011 10:54 am    Post subject: Reply with quote
I hope this is the correct way to report that (repeated) attempts to download the 3.6 Beta produce the following error message:-
"Gateway Anti-Virus Alert
This request is blocked by the SonicWALL Gateway Anti-Virus Service. Name: Onescan.A_7 (Trojan)"
I've tried reporting it to Zen but they're always engaged.
Apologies in advance if I should have reported this in some other way.
Ash10
PostPosted: Thu Aug 25, 2011 11:12 am    Post subject: Reply with quote
Nothing to do with Zen (the ISP) - it's your AV getting a false positive (A quick Google search suggests that this isn't uncommon for SonicWall)...
westcatford
PostPosted: Thu Aug 25, 2011 1:13 pm    Post subject: Reply with quote
Thank you for the prompt response.
Unfortunately (in terms of an easy answer) I don't use SonicWall. And, for what it's worth, turning off my a/v (Eset) and my firewall (Win7) have no effect on the problem.
But thanks anyway.
westcatford
PostPosted: Thu Aug 25, 2011 4:47 pm    Post subject: Reply with quote
I've established that it's my ISP's firewall that is blocking the file. They also tell me - false positive or not - that Zen are reporting it as infected as well.
Is there any other mechanism by which you could suggest I access the file?
deeranwith
PostPosted: Sat Nov 12, 2011 1:59 pm    Post subject: Camera Manager 3.5 beta issues Reply with quote
I have been using 3.6 beta for sometime now and it works fine with my Win 7 ultimate and IE9 setup. EXCEPT once it finds an update and you install it, it continues to remind you. Manual cancellation works but this is not the behaviour experienced with previous versions.
Has anyone had a similar issue? Question
digitalker
PostPosted: Sat Nov 12, 2011 2:24 pm    Post subject: Re: Camera Manager 3.5 beta issues Reply with quote
I think this behaviour started some time ago when Garmin last updated the POI Loader software. Its being happening with CM 3.0 as well. I'm hoping Ash10 can fix in due course.
deeranwith
PostPosted: Fri Nov 18, 2011 12:17 pm    Post subject: Reply with quote
Thanks I will await Ash's pronouncement on this bug in due course.
M
dales
PostPosted: Fri Nov 18, 2011 4:48 pm    Post subject: Reply with quote
Yes, I think digitalker has got it.
With PoiLoader.exe version 2.6, all was well.
With Poi Loader.exe version 2.7, the Ash icon continues to flash.
(Note the subtle change of name of the exe).
Hope this helps.
Dales.
Metblackrat
PostPosted: Fri Dec 23, 2011 6:00 pm    Post subject: Reply with quote
I have a problem since updating to 3.6 beta.
If I open Camera manager, the program does not respond, it just sits in the tray and I cannot do anything with it. I can only close it in task manager. However, if i open a second instance of camera manager, that one runs fine.
The first program seems to create some erroneous files in my poi folder called output.csv, specs.tmp, redlight.tmp, gatso.tmp and mobile.tmp.
I have tried deleting all instances of the program and re-downloaded it but that hasn't helped. Does anyone know where the settings are stored?. Perhaps this file is corrupted.
Any ideas?.
Metblackrat
PostPosted: Sat Dec 24, 2011 6:56 pm    Post subject: Reply with quote
Sorted it by changing every possible setting in camera manager, closing it, then re opening it and putting the settings back as they were.
Seems like the settings were corrupted.
kkk
PostPosted: Thu Mar 22, 2012 9:57 am    Post subject: Re: Camera Manager 3.5 beta issues Reply with quote
Go into Properties on POILoader and where the name is in
Target take out the space between `i` and `L` and apply.
It then it works fine.
TheGavsta
PostPosted: Fri Mar 23, 2012 2:35 am    Post subject: Reply with quote
Hi All
Is there any workaround to include the French and Swiss cameras in the European download for Camera Manager?
borgmaster
PostPosted: Fri May 18, 2012 10:22 am    Post subject: Reply with quote
Since upgrading to FF 12 my computer at start up keeps asking for a digital certificate for CM. I have to click on run for my computer to continue to load and eventually CM is loaded ok. Is there a way of getting round this? I`m using Vista 32 Bit home premium.
PostPosted: Fri May 18, 2012 3:10 pm    Post subject: Reply with quote
It took me about 15 seconds to Google for this. Does it help?
Page 67 of 77
22.043 (17 Apr 24)
