Pocket GPS World :: View topic - Rechargeable Lithuim Battery not holding a charge
reece34
PostPosted: Tue Jun 28, 2011 8:40 pm    Post subject: Rechargeable Lithuim Battery not holding a charge Reply with quote
Plugged my Satmap into the USB and left it on charge overnight. It was showing it was charging so i thought in the morning it would be fully charged.
I unplugged it and tried to turn it on but its dead.
Anyone had any issues like this??
PostPosted: Tue Jun 28, 2011 9:08 pm    Post subject: Reply with quote
How old is the battery as they do have a life span and beyond a certain point they simply won't retain a charge, this applies to all Li-Pol type batteries - Mike
reece34
PostPosted: Tue Jun 28, 2011 9:12 pm    Post subject: Reply with quote
less than 3 months.
its only the 2nd time ive ever tried to charge it
rothers
PostPosted: Tue Jun 28, 2011 10:15 pm    Post subject: Reply with quote
Are you charging with the mains charger or a PC USB port ?
reece34
PostPosted: Tue Jun 28, 2011 10:23 pm    Post subject: Reply with quote
tried both
rothers
PostPosted: Wed Jun 29, 2011 9:27 am    Post subject: Re: Rechargeable Lithuim Battery not holding a charge Reply with quote
When you unplug after charging the unit remains on, no need to turn it on. Was it dead immediately after charging or was it dead a few days later ? maybe you forgot to turn it off after the charge, yep I've done that Evil or Very Mad
Was it really dead or just in hibernate mode. I disable hibernate, seems a daft feature to me, if you want to save power turn it off, the Satmap gets a lock quick enough from cold anyway.
My Satmap is over 2 years old and the Lipol still has enough capacity for a full 8 hours+ use after an overnight charge so maybe you have a faulty unit or battery.
reece34
PostPosted: Wed Jun 29, 2011 7:04 pm    Post subject: Re: Rechargeable Lithuim Battery not holding a charge Reply with quote
As soon as i unplug it from either the mains or laptop i then try to turn it on but nothing happens.
When i use 3 AA batteries everything works fine.
Sent satmap an email last night but no reply yet.
One other thing.
I use Memory Map to plot my routes, i then convert them to GPX to use them on my Satmap. Am i better off converting them to tracks as it just said some of my routes have over 500 waypoints and it may affect the Satmap
rothers
PostPosted: Thu Jun 30, 2011 1:31 pm    Post subject: Re: Rechargeable Lithuim Battery not holding a charge Reply with quote
reece34 wrote:
One other thing.
Same here. I rode the Llangollen Panorama Audax a few weeks using my Satmap using a route with over 2000 points and it was fine, you can safely ignore that warning although it is good practise to keep the waypoints to a minimum.
If you do want to reduce an existing route the yes convert to a track and then you can use track properties to reduce the total number of points, it will be less accurate but still probably fine to navigate by.
22.034 (27 Mar 24)
