Pocket GPS World :: View topic - Destinator with Co-Pilot Jacket
TheGoodMan
PostPosted: Sun Sep 14, 2003 8:04 am    Post subject: Destinator with Co-Pilot Jacket Reply with quote
I have got Co-Pilot Jacket (the new one) is it possible to use PowerLOC Destinator with it?
When I try to use Destinator its keep coming up with no GPS
Help please.
With thanks
The new co-pilot jacket is actually manufactured by Emtac the same guys who make the Bluetooth GPS receiver.
It is possible to use the sleeve with destinator. Depending on which iPaq you are using the comport will differ, but I think I set mine to com5 4800 NMEA. I cant try it out for you as my iPaq is being repaired and I no longer have the sleeve.
TheGoodMan
Thanks,
I have try doing auto search where it checks all ports..keeps coming up with no GPS. I have Ipaq 3970.
Help Please
MJ
Quantum
Actually the jacket system itself is made by Transplant. Gutz are by Emtac.
It is unfortunately not compatible with Destinator.
George the Second, to wounded vets in the Amputee Care Center, Jan. 1, 2006:
"As you can possibly see, I have an injury myself -- not here at the hospital, but in combat with a cedar. I eventually won. T
And it's not compatible with most applications due to it's stealthing of the COM port. TomTom Navigator will work.
jayshry
Quote: Originally posted by TheGoodMan on 18 February 2003
Help please.
With thanks
Every single post you write says that co polit is the best and that no other program compare sot it, so I ask you WHY do you want to use destinator with your co polit jacket - please answer that.
I actually purchased a Co polit because of you and these are the problems I find:
1) The jacket by itself is very slow at getting a fix, just like the navman
2) The speech cracks up constantly - it is a very bad error in the software given that I have the best ipaq 3970 - you forgot to mention this mate
My conslusion is that Tomtom is the best and I think you realise that co polit is really still in its production stage and takes up way too much space on your memory card and has absolutely rubbish speech
johnmar
I am strongly contemplating buying CoPilot 3.5 to run on an iPAQ 3830.
Can I refer you to "Voice Prompts" posted on this forum on 27/01/2003 as there are a whole string of postings from CoPilot users having sound/speech problems on 3970's similar to your own.
This might be of use.
John
sconebum
Dave,
Can you please explain stealthing of the COM port referred to above.
I have the new Co-Pilot sleeve and software, which is OK, but I still use my old 1.4 Navigator because it's just better, faster and easier to use.
However, I got a loan of Destinator 2.0.03 beta to try out, and cannot get the Destinator software to detect the Co-Pilot GPS sleeve. Any hints or advice?
Will version 2 of Navigator work with this sleeve, either?
Thanks,
With GPS Receivers, they talk on a specific assigned COM port and baud rate, eg COM1 and NMEA 4800. The Emtac Sleeve I've tried scanning every COM port using NMEA baud rates and SiRF baud rates and haven't been able to get a connection. So it appears that the Emtac either broadcasts on a different COM port which you can't usually see, or a strange baudrate which you can't select. Either way it appears stealthed. Some applications work like TomTom Navigator and CoPilot, but other applications which don't know the internal settings will fail like WinFast Navigator, PowerLOC Destinator etc.
You won't get the sleeve to work with Destinator, it's a known problem and PowerLOC have posted this on their support page.
22.043 (17 Apr 24)
