Pocket GPS World :: View topic - How to correct map error Error
Paul80
PostPosted: Thu Nov 25, 2010 11:12 pm    Post subject: How to correct map error Error Reply with quote
Hi Guys
Hopefully a quicky
On my TT540 I tried to correct a map error, a road sown a one way was actualy two way, unfortunatly all I managed to do was revers the direction of travel so its still showing one way but now the other way.
How do I remove this error.
Paul
PaulB2005
PostPosted: Thu Nov 25, 2010 11:16 pm    Post subject: Reply with quote
Just do it again and make it two way?
Paul80
PostPosted: Thu Nov 25, 2010 11:25 pm    Post subject: Reply with quote
Thanks for the quick reply, trouble is there is only an option to reverse direction and not to make it 2 way, also I am not 100% sure where on the route it is and because its now going against my direction of travel the TomTom takes me off route quite a way before it and routes me around the road.
I though these map corrections where stored on the Device hard drive and if the file was deleted the corrections would be removed.
Paul
PaulB2005
PostPosted: Thu Nov 25, 2010 11:42 pm    Post subject: Reply with quote
I'm not sure how to undo a correction but there should be an option to make the road two way.
I can't see why you couldn't make it two way as reverse traffic direction allows you to choose which directions are allowed or not. You can just allow both directions.
Paul80
PostPosted: Thu Nov 25, 2010 11:56 pm    Post subject: Reply with quote
I just checked it on a road near me so I could put it right afterwards and it definatly only gives an option to reverse the flow of trafic, there is no option to have it going both ways.
Paul
PaulB2005
PostPosted: Fri Nov 26, 2010 12:01 am    Post subject: Reply with quote
Sorry just realised what the problem is. As it is a one way road for some reason tomtom assume you want to reverse the direction. It does not give you be option to make it two way from that screen. To correct a one way road to two way you need to use the unblock road function and then unblock the blocked direction.
Paul80
PostPosted: Fri Nov 26, 2010 10:13 am    Post subject: Reply with quote
Ok Thanks
I am going that way again today, if I can find it without tomtom trying to route me away before I get to it I will try and correct it.
paul
Paul80
PostPosted: Fri Nov 26, 2010 11:49 pm    Post subject: Reply with quote
I Managed to find the bit of road again today and set the unblock correctly. The thing that surprised me was that although the bit of road is only about 2 hundred yards long tomtom had it split into 4 sections so I had to correct each section.
Still its all done now.
Paul
22.034 (27 Mar 24)
