Pocket GPS World :: View topic - memory map on road angel 7000
sajeelnoor
PostPosted: Sun Jun 13, 2010 2:53 pm    Post subject: memory map on road angel 7000 Reply with quote
I want to run to run memory map on my road angel, here is what i have find out so far, 1) i need a spare sd card, 2) i have to install some file on sd card before installing memory map, but can i run any memory map or must it be os versions only ?
Sajeel
rothers
PostPosted: Mon Jun 14, 2010 9:55 am    Post subject: Reply with quote
What version of Memory Map do you have ?
sajeelnoor
PostPosted: Mon Jun 14, 2010 8:17 pm    Post subject: memory map on road angel 7000 Reply with quote
version 5.4.2
AllyCat
PostPosted: Mon Jun 14, 2010 9:14 pm    Post subject: Reply with quote
AFAIK, the RA7000 will only work with the "_CE" version of the software because the RA is a Windows CE (not Windows Moblile) device. I believe the latest version of the CE software was v5.2.0 before the RA was discontinued in favour of the Adventurer 2800. It's possible (but unlikely) that the software upgrade for the 2800 when it's re-released (it was withdrawn due to a bug) will work on the RA7000.
The .MMO overlay data (Routes, Tracks and Waypoints) file format was changed around v5.2.? and is not backwards-compatible, so you may have problems transferring data between the RA and PC software.
For legitimate upgrade information the MM support forum and downloads page may be helpful. But for "Win CE hacks" you will have to look elsewhere.
Cheers, Alan.
rothers
PostPosted: Tue Jun 15, 2010 9:00 am    Post subject: Reply with quote
You can download the RA 7000 Memory Map 5.4 client from here:
http://www.memory-map.co.uk/downloads/RA/MM_RA_540.zip
Other stuff you'll need such as Active Sync or WMDC you can get from the RoadAngel website
sajeelnoor
PostPosted: Tue Jun 22, 2010 10:38 pm    Post subject: RA 7000 Reply with quote
Thanks for all your replies
Saj
22.042 (10 Apr 24)
