Newsletter
Pocket GPS World :: View topic - Satnav with 3.5mm audio out?
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Motorcycle GPS Users
smartroad
PostPosted: Sat Jan 02, 2010 4:28 pm    Post subject: Satnav with 3.5mm audio out? Reply with quote
I have been looking for ages for a reasonable satnav that has audio output. I am looking to get a waterproof bike bag so it doesn't need to be an overpriced TomTom Rider or Garmin Zumo. For christmas I was brought an Autocom system and want the audio pumped through that.
Does anyone out there have a gps system which works well and has an audio output?
I'd be really greatful!
Snudge
PostPosted: Sun Jan 03, 2010 8:18 pm    Post subject: Reply with quote
If you read THIS thread you will see that it is possible to add a jack socket to the One.
Here is a pic of my modified One XL although that is the original XL and I don't know if there is still room in the latest models. The mount is from RAM and is very stable.
I use a cheap earphone off ebay and it works extremely well.
TomTom ONE XL App 7.162 Map UK 710.1571
AliOnHols
PostPosted: Mon Jan 04, 2010 9:45 am    Post subject: Reply with quote
Hi smartroad, If the SatNav does not have to be bike specific the TT Go730 has a 3.5mm audio out jack fitted as standard. I put my 730 in my TankBag map case, the display is not too clear through the plastic cover but the audio output works well.
TT Go720's have it fitted also. TT Go 730's and 720's are now being replaced by newer models so you should be able to find one at a good price.
I am not sure if Go520's have 3.5mm output (I believe that they are the same as 720's but with Uk maps not European) but mikealder recently did an article where he pointed out that CPC were offering TT Go520's at reduced prices. If this interests you and if they are still available from CPC, please double check that it has the output you require before buying.
Good luck, let us know how you get on.
EDIT. Just remembered that my old Garmin Nuvi 760 had an 3.5mm audio output also.
Garmin Nuvi 2599
SatMap Active 10 & 12.
Snudge
PostPosted: Tue Jan 05, 2010 2:49 pm    Post subject: Reply with quote
Doesn't the 720 have a microdrive rather than solid state? If so, perhaps not as durable on a bike?
PostPosted: Tue Jan 05, 2010 4:49 pm    Post subject: Reply with quote
The only TomTom devices to employ a spinning hard drive were the Go-700 and Go-910 all others employ either an SD card or built in Flash (Solid State) memory - Mike
Snudge
PostPosted: Tue Jan 05, 2010 9:35 pm    Post subject: Reply with quote
Ok thanks Mike.
SOELEY
PostPosted: Tue Jan 05, 2010 9:43 pm    Post subject: Reply with quote
The Garmin Nuvi 765T has a 3.5mm jack. ot sure about the rest of the Nuvi range.
Garmin Nuvi 765T
Toyota iQ3
IPBR21054
PostPosted: Tue Aug 24, 2010 1:09 am    Post subject: Reply with quote
Snudge has put up a link which reads if you read THIS thread etc etc,i am the person who started the thread and did the conversion on my TT one.It has been some time now and still to this day it works 100%.Hope you did it ok and saved ££££££££
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Motorcycle GPS Users All times are GMT + 1 Hour
20.083 (17 Aug 22)
