Newsletter
Pocket GPS World :: View topic - MM emtac BT blues
MM emtac BT blues
uro_who
PostPosted: Fri Apr 09, 2004 9:06 am    Post subject: MM emtac BT blues Reply with quote
I am using MM with an emtac and 4150. I just cant get the set up to work well.
Emtac came set on port 6. This is what I usually do:-
Connect emtac via BT (paired device)
run MM
if I leave MM on port 6 then it connects.
GPS works for a short while say 90 seconds
Then dies
multiple errors, cant connect to com port rs232 error etc
need to do a soft reset and start again
If I set MM to port 8 everything locks out immediately and has to be reset without ever making a connection.
I mainly wanted to use it for walking but was considering it for aviation (bought CAA maps). This situation might make it slightly dangerous for aviation use!
crux view can see the BTGPS and stays connected indefinately.
Any idea whats going on here?
Many thanks.
Mike Henley.
Oldie
PostPosted: Fri Apr 09, 2004 5:00 pm    Post subject: Reply with quote
Mike,
When using my Emtac BTGPS with MM I use Menu | GPS | Setup... and Manufacturer NMEA, Port COM8: Bluetooth Serial Port. The Baud rate does not appear to matter as I have just tried 4800, 9600 and 19200 and Satellites were visible on all settings.
I am using MM 2004 now but it was the same on the earlier version. My PDA is an iPAQ 3970 running PocketPC 2002. The Emtac is set to NMEA not Sirf. The Emtac setting can be changed using Crux_View.
uro_who
PostPosted: Fri Apr 09, 2004 9:09 pm    Post subject: BT dropout Reply with quote
Thanks Richard,
I've tried all of the usual. Maps moved from SD to main memory. Tried device paired and unpaired. Not running any other software. It just decides every now and then (30-200 seconds) its had enough and then will not reconnect. It certainly would not be in any way usuable.
Typically I bought the maps, gps and pda from 3 different sets of people so I haven't even got the send it all back and ask the vendor to sort it out option.
Are you connected via blue tooth and dont get drop outs?
I am starting to worry that no-one has actually managed to make this work on a 2200 or 4150. I see lots of posts about bluetooth stack failures and BT drop out. After all, a 4150 is a 2200 with wifi. I also note that the 2200 has a rom update, is it beyond the bounds of possibility that HP forgot to make the relevant changes in the 4150 ROM?
Is it my pda version, should I take it back and get a tosh e800 or is the memory map, btgps an emporers new clothes situation and no-one has managed to make it work outside their study?
Mike H.
MrT
PostPosted: Sat Apr 10, 2004 7:38 am    Post subject: Reply with quote
Out of interest have you recently installed the TomTom GPS 3 update? This seem to cause the same effects on my MMOS2004
PostPosted: Sat Apr 10, 2004 8:37 am    Post subject: Reply with quote
I have the Emtac, and many other BT GPS devices working correctly on my 2210, so if the 4150 is the same architecture then this is not the issue.
I can run both MM2003 and MM2004 with no problems. The only drop out problems like you are describing that I have experienced occured with a faulty GPS and another time when the processor was heavily loaded.
Are you running anything else in the background when this occurs?
Editor, PocketGPSWorld.com
uro_who
PostPosted: Sat Apr 10, 2004 10:38 am    Post subject: EMTAC blues Reply with quote
Thanks,
I have tried with everything else stopped. No difference. The only other thing of note is that if I try to use crux_view to change any settings on the emtac the whole system locks and then comes up with a communication error. This makes me suspect the BTGPS.
The MM software was the first thing installed on the PPC so I don't think there is a clash. I haven't got any other mapping software loaded.
What should I do/send back for an exchange first. I was thinking BTGPS, any thoughts.
Ta
Mike Henley
uro_who
PostPosted: Sun Jul 11, 2004 7:36 pm    Post subject: EMTAC blues gone Reply with quote
I thought I ought to update this thread. I sent the emtac back and the replacement is perfect. Great results with memory-map and tomtom3.
The reason I took so long to reply was that I was having so much fun!
Mike H.
PostPosted: Sun Jul 11, 2004 8:44 pm    Post subject: Re: EMTAC blues gone Reply with quote
Glad everything worked out for you.
20.082 (10 Aug 22)
Terms & Privacy
