Pocket GPS World :: View topic - Becker Z205 default sound
Goto page Previous  1, 2
linknet
PostPosted: Mon Jul 27, 2009 9:24 pm    Post subject: Reply with quote
dougproctor wrote:
Software version 8.5.1.88270, Image version R05.3.0565.0224
Build date Apr 30 3009.
I will look for other audio files. The noise I get is about 200 yards before the speed camera so it is not an overspeed warning, just a warning the camera is coming up.
Thanks guys
Doug
iGO8 notifies of a speed camera from about 900 to 400 metres depending on your actual speed then at 200 metres gives an overspeed warning if you are over the speed camera limit, so I still suspect it to be the overspeed warning.
Regards
linknet
dougproctor
PostPosted: Tue Jul 28, 2009 1:30 pm    Post subject: Reply with quote
Sorry, another question. If !alert5.wav is the overspeed warning, what is used as the long way away warning? Perhaps that's the one I need to change.
In my data.zip file I have 1-5 alert files and one number 2a. This I think was !alert7 or even the original 5 but I renumbered it to avoid overwriting it. Are there 7 alert files in the folder or just 6 and I need to delete 2a?
Doug
Returned to a proper Garmin although still have Co-Pilot on a Galaxy S3!
linknet
PostPosted: Tue Jul 28, 2009 1:47 pm    Post subject: Reply with quote
Doug
iGO8 uses !sectionbeepA and !sectionbeepB, one at distance and one when under 200m with no overspeed, I can't remember which is which.
iGO8 has !alert1 to !alert6, six files.
linknet
dougproctor
PostPosted: Tue Jul 28, 2009 2:00 pm    Post subject: Reply with quote
Thank you for that info. I will look at those then.
Regards
Doug
Later. Used a free AT&T speech maker to make my own sounds and replaced those three files in the Data.zip file. Where's a speed camera when you need one!
dougproctor
PostPosted: Sun Sep 27, 2009 3:06 pm    Post subject: Reply with quote
And still gives out the horrible squeal even though I have changed all those sounds! Must be getting them from somewhere else. Any ideas guys?
Doug
dougproctor
PostPosted: Sat Oct 03, 2009 5:40 pm    Post subject: Reply with quote
This has really stumped me. I have changed all these sounds but the damn thing still makes this strangled sound. Are we sure that the Becker sound files are the same as the IGo 8 ones? I am not convinced.
Doug
dougproctor
PostPosted: Sun Oct 11, 2009 4:43 pm    Post subject: Still no good....................... Reply with quote
Anyone help me please? The only thing I don't like about this unit is the warnings for speed cameras - like a constipated duck!!!
Doug
Crying or Very sad
PostPosted: Sun Oct 11, 2009 4:55 pm    Post subject: Reply with quote
Doug. Has the Becker got the software on SD or is in in internal memory?
dougproctor
PostPosted: Sun Oct 11, 2009 10:34 pm    Post subject: Reply with quote
Hi. On it's inbuilt 4 Gb hard drive. The wave files are in a zipped DATA file. I have replaced the three files I was told were the ones and get a shrill sound from the speaker. Has me stumped!
Thanks for your thoughts. Perhaps I ought to ask Becker but it has taken me about three months to try and get a promised map update nearly sorted. Had to write to the Chairman to get it looked at!!
Doug
PostPosted: Mon Oct 12, 2009 7:15 am    Post subject: Reply with quote
Do you have an SD card in it with any Becker stuff on it. I think that the software looks at the SD first for stuff (bit I am open for correction)
dougproctor
PostPosted: Mon Oct 12, 2009 8:35 am    Post subject: Reply with quote
Hi. There is a SD card in the slot but have not looked at that. Might be something on there. Will have a look and come bank. Thanks.
Doug
dougproctor
PostPosted: Mon Oct 12, 2009 8:08 pm    Post subject: Reply with quote
Hi again,
There is a IGo 8 folder but it is empty. So back to square one!
Doug
Page 2 of 2
22.044 (24 Apr 24)
