Pocket GPS World :: View topic - No Map Found - error message: Help!
swebb
PostPosted: Sun Oct 04, 2009 2:39 pm    Post subject: No Map Found - error message: Help! Reply with quote
I've just restored a back up of my Go510. when I restart I get this message!
I can't do anything. It will connect to my PC and I can explore the memory card.
Can anyone help please?
PostPosted: Sun Oct 04, 2009 2:59 pm    Post subject: Reply with quote
Using Explorer, can you see a map folder? (called Western Europe or whatever your maps name was)
How large is it? (It should be at bit less then 1GByte at least)
It needs to contain at least the following files
* cline.dat
* cname.dat
* cnode.dat
* faces.dat
* mapinfo.dat
* poi.dat
* tables.dat
* tmccodes.dat
* traffic.dat
* mapname.meta(only map v705 or higher will have/need this file)
* mapname.meta.dct (only map v705 or higher will have/need this file)
* mapname.pna
How was the backup made? (Exploer or TT Home)
Tried a reset?
Anything HERE that helps?
swebb
PostPosted: Mon Oct 05, 2009 6:09 pm    Post subject: Reply with quote
Thanks for that info Andy_P. I checked the files and they were all there. I put the SD card direct into my PC instead of via the TT. I was prompted to scan and fix - which I did. I reset the device and it seems to be stable... If this happens again, I'll look at a new SD card.
