Oldboy Pocket GPS Moderator
Joined: Dec 08, 2004 Posts: 10641 Location: Suffolk, UK
Posted: Wed Aug 26, 2009 6:37 am Post subject: |
darrenintheeast wrote: | My mate has a 910 ( and hes never updated the maps ) and it doesnt do it on his.... | My 910, with the 835 W&C E Map, also takes the correct route _________________ Richard
BigPerk Frequent Visitor
Joined: Sep 06, 2006 Posts: 1618 Location: East Hertfordshire
Posted: Wed Aug 26, 2009 11:01 am Post subject: |
Doesn't explain WHY, but is there a 'no u-turns thank you' option on the satnav? Might solve this particular problem, though not necessarily any general 'funny-routing' in the algorithm. _________________ David
(Navigon 70 Live, Nuvi 360) |
GerryC Pocket GPS Moderator
Posted: Wed Aug 26, 2009 11:42 am Post subject: |
As I have the WCE map, I can't check but could someone who is affected try the following...
Set up a route from just before the roundabout to just after it. If I'm reading the posts right, this should offer the "detour" route with the U-turn. Now make sure that the status bar has 'time remaining' set and do a demo. Note down what the remaining time is at the beginning of the journey.
Now do the same route with the "shortest route". Again note the remaining time at the beginning but look carefully at the demo at 100% or lower. At any time, does the "time remaining" jump suddenly?
I'm wondering if this is a similar map error to the one that was on a roundabout on the M40(?). Then, the "fastest" route was to go down the motorway and turn around at the next junction rather than turn right on the roundabout at the junction you were on. _________________ Gerry
TomTom730T
Cameralert for Android
Brodit ProClip mount |
Anita Pocket GPS Moderator
Joined: Mar 15, 2006 Posts: 3219 Location: Windlesham, Surrey
Posted: Wed Aug 26, 2009 12:50 pm Post subject: |
Right, I hope I've got this right!
Fastest: 1:45 mins, 0.3 miles
Time remaining counts down until it joins the roundabout, when it jumps from 1:05 to 0:30.
Shortest: 2.25mins, 275 yards
Time remaining counts down until it leaves the roundabout, when it jumps from 2:20 to zero!
Hope that what you want, Gerry. _________________ Anita
TomTom VIA 135 - App 12.075
UK map 1125.12264
Samsung Galaxy S21 |
Posted: Wed Aug 26, 2009 1:57 pm Post subject: |
Thanks Anita. It wasn't quite what I was expecting but those jumps are the cause of the routing error.
I was expecting it to jump between the exit from and subsequent entry onto the roundabout but the "bigger" jump on the shortest route is why it routed the way it did on the "fastest" route.
Not a lot can be done as far as I know except point out the error to TomTom and hope they fix the timings on the next release. The fact that other maps covering the same area appear correct should make this easier but we are talking about TT here. _________________ Gerry
TomTom730T
Calomax Lifetime Member
Joined: Sep 30, 2005 Posts: 988 Location: St Martin's, Guernsey
Posted: Wed Aug 26, 2009 4:25 pm Post subject: |
GerryC wrote: | Not a lot can be done as far as I know except point out the error to TomTom and hope they fix the timings on the next release. | _________________ TT Go Essential |
TomDavison Lifetime Member
Joined: Mar 02, 2006 Posts: 384 Location: Bedford, England
Posted: Mon Aug 31, 2009 5:56 pm Post subject: |
If it's a fastest route problem, try using limited speed, and set your max speed to 70mph. I always use limited speed anyway, with a max speed of 65mph, and this gives me better timing on long motorway journeys. |
darrenintheeast Regular Visitor
Posted: Mon Aug 31, 2009 7:23 pm Post subject: |
i've got a new sat nav now.
TomTom XL IQ routes with europe maps....
happy now |
docdoc Occasional Visitor
Posted: Wed Sep 02, 2009 7:54 pm Post subject: |
Do you use mapshare? I noticed that I got funny routing after downloading some mapshare updates and I guessed that someone had put some crap correction in that diverted my route away from a certain road, so I changed my mapshare settings to my corrections only. |
mpwilson99 Lifetime Member
Joined: Jun 30, 2007 Posts: 462 Location: Hickstead, Sussex
Posted: Wed Sep 02, 2009 8:50 pm Post subject: |
docdoc wrote: | Do you use mapshare? I noticed that I got funny routing after downloading some mapshare updates and I guessed that someone had put some crap correction in that diverted my route away from a certain road, so I changed my mapshare settings to my corrections only. |
Mapshare doesnt seem to be a factor in this error.
It comes up with this strange routing on the UK&ROI v8.35.24** maps without any mapshare intervention.
I still cannot believe there are errors in the v8.35 maps that have not been fixed & been there since my first GO circ 2005. _________________ TomTom 700 GO user since Dec 2005.
TomTom HTC HD2 user since Jul 2012. |
maca2 Frequent Visitor
Posted: Thu Sep 03, 2009 8:46 am Post subject: |
Mapshare was the cause of my strange routing on my 730T, it would take me off the A3 northbound at Guilford then go into guilford then back onto the A3 making the route much longer.
I posted here removed mapshare & it works perfectly but even with just TT mapshare updates loaded the problem returns so it's their mapping/updates that are wrong. I have removed all mapshare updates & no longer use it. |
Posted: Thu Sep 03, 2009 8:10 pm Post subject: |
I tried this route on my Go 740 - v8.37 software and the 815 UK&ROI map. I get the same problem where it turns left at the first roundabout then does a u-turn if choosing the fastest route. On my PDA with v7.9xx software + 835 UK&ROI map it also does this. The 835 Western & Central Europe map is ok.
So must be a quirk with the UK&ROI map data.
There must be a few errors on roundabouts as there's a particular route I takethrough Newcastle-under-Lyme which I know is the fastest route but the TT always calculates a different route. When you get to the roundabout in question, the time to destination suddenly drops by about 8 minutes when you get to the other side! So obviously the TT calculates this as 8 minutes longer than it actually takes! |
