Pocket GPS World :: View topic - Tomtom Version 3 and Ipaq 3970 and 3950
spewy
PostPosted: Mon Jun 28, 2004 6:34 pm    Post subject: Tomtom Version 3 and Ipaq 3970 and 3950 Reply with quote
Sorry if this subject has already been covered. I've searched through the threads and found similar probs with the 2210 but not exactly.
We are currently testing TT3 with the 3950 and the 3970. In both cases we are findng with the latest release that if you turn off the ipaq without exiting the programme correctly and while locked onto a satelite the application freezes or becomes unuseable. The only way to correct the situation is to try and exit Navigator or peform a soft reset, usually being the latter. At present we have solved the problem by rolling back the GPS driver to version 2.08. The ipaqs are running pocket PC 2002 with the latest Rom versions and all Rom patches and updates installed. This is also not an SD card issue.
Has anyone else had similar problems and have you found any other solutions to the problem. We will be sending a unit with the problem direct to TomTom for testing and will post the results. To date this problem has occured on every ipaq 3950 and 3970 we have installed TT3 on. Although we are dealing with TomTom direct they are in effect denying there is a problem hence why we are sending the unit back complete with the problem installed. Sorry if this subject has already been covered but I'd really appreciate any views, solutions etc on this.
Thanks for your help.
spile
PostPosted: Mon Jun 28, 2004 8:41 pm    Post subject: Reply with quote
Sadly yes.
This has been discussed previously and sadly version 3.03 isn't any better Sad
It basically means that you cannot trust TT3 to commence navigation if a route has been planned away from the car, which presumably is how many of us use a route planner!
As you have found out, the only way out is to quite TT3 before turning off.
I did use the itinerary feature the other day and this seemed to survive being turned off. Not tested this in detail however.
MrT
PostPosted: Tue Jun 29, 2004 9:14 am    Post subject: Reply with quote
I cannot see why you cannot do this. Plan your route, exit TomTom, turn your PDA off. In your car, turn your PDA on, start TomTom and your route is still there.
Grahamcol
PostPosted: Tue Jun 29, 2004 12:01 pm    Post subject: Reply with quote
I have the same problem with the 3950.
The answer I have found is to quit the application as you indicate.
I would like to try the 2.08 driver. Where can I get it from?
Graham
Tim Buxton
PostPosted: Tue Jun 29, 2004 12:22 pm    Post subject: Reply with quote
Just here.
Tim
gokhart
PostPosted: Tue Jun 29, 2004 12:51 pm    Post subject: Reply with quote
how do you know which version of driver you have ?
Privateer
PostPosted: Tue Jun 29, 2004 12:58 pm    Post subject: Reply with quote
Hi Gokhart,
Tap the Navigator screen, to get the Navigator Menu. Tap “More” until you get the icon for GPS Status. Tap GPS Status, then tap the tab “GPS”.
You will see a picture of the world map and in the bottom left hand corner (under Australia) you will see the version and build numbers. Thumbs Up
Robert.
Garmin Camper 770 LMT-D
22.034 (27 Mar 24)
