Andy_P Pocket GPS Moderator
Posted: Wed Mar 04, 2009 11:37 pm Post subject: |
technik wrote: | I was unable to update my NA Map under LMG until I called TTS, and within 24HRS I had the new 825 NA Map, and I am in the UK, so are things changing with TT Support for the better? |
No... because meanwhile other TT support staff are being adamant that people cannot have v825 under the LMG. |
liamchadwick Occasional Visitor
Posted: Wed Mar 04, 2009 11:39 pm Post subject: |
unfortunately for me i downloaded tomtom 8.15 maps an hour before the home recognised 8.25 maps so as soon as my download was complete and reconnected to home it said a newer map was available. I rang tomtom up and they said unfortunately i had the latest maps at the time of connection under the LMG and i could purchase 8.25 if i wished to do so.
How annoying is that though, soon as your new map update finishes you get a message saying there is a newer map available
Not impressed but i suppose just the way the cookie crumbles... |
Posted: Thu Mar 05, 2009 1:20 am Post subject: |
Well i'm sitting here with 810 maps loaded and TT have not only confirmed i am entitled to the 825 maps, but they've also now told me they were loaded to the LMG server on Monday 2nd March 2009 and
Quote: | ...and can be downloaded and installed at any time. |
But home still only offers me the 815 maps..... |
silversurfer Regular Visitor
Joined: May 28, 2004 Posts: 120 Location: sutton on sea .lincolnshire
Posted: Thu Mar 05, 2009 7:09 am Post subject: |
well after all my efforts with trying to get the latest maps with the LMG and tomtom adamant i would not get them i have had to download the 815 that tomtom home was still showing , not very happy _________________ _________________________
chris |
tomcat76 Lifetime Member
Joined: Aug 18, 2004 Posts: 100 Location: West London
Posted: Fri Mar 06, 2009 1:58 pm Post subject: New map - File Error - pna.log |
LIke some others I bought the years subs for maps... but a problem, I received the email to say there is a new map to download... but it will not install, throws up an error about a file is in the archive that should not be there!!!
ERROR: DesktopLib/InstallToDevice/GetInstallable/InvalidFile: The archive file contains this file: pna.log
The file should not be part of this archive:
I've contacted TT and just waited on a reply, I also auto reported it but of course its done anon so I won't get a reply via that means... _________________ Regards Steve :-) |
dhn Frequent Visitor
Joined: Oct 08, 2007 Posts: 2544 Location: Toronto CANADA
Posted: Fri Mar 06, 2009 2:18 pm Post subject: |
So what happens if you open up the compressed file, see if one of the files in the .cab (or .zip) is pna.log and, if it is, remove from the .cab and then try to install? _________________ David |
Posted: Fri Mar 06, 2009 2:24 pm Post subject: |
Hi dhn,
Tried that, its a cab file and there is no option to allow you to delete it, that was the first thing I tried as done it before with other files... _________________ Regards Steve :-) |
Posted: Fri Mar 06, 2009 3:05 pm Post subject: |
What if you expand the cab file so that you have all the individual files. Then compress all the files again **except** for that file. Wouldn't that accomplish the same thing? _________________ David |
Posted: Sat Mar 07, 2009 7:04 pm Post subject: |
Hi, I've no idea as I don't have anything to compress it again as a cab file.
I really want to know why that file is there and where it come from, I used TT home to download it and I assume that has come from TT like that. _________________ Regards Steve :-) |
Mullet Frequent Visitor
Posted: Sun Mar 08, 2009 12:24 pm Post subject: |
Download the trial version of WinRAR if its worth pursuing. |
Posted: Sun Mar 08, 2009 6:24 pm Post subject: |
Mullet wrote: | Download the trial version of WinRAR if its worth pursuing. |
Does it do Cab files, I have winrar but it's a fairly old version? _________________ Regards Steve :-) |
Posted: Sun Mar 08, 2009 6:27 pm Post subject: |
WinRar will extract files from CAB downloads, it is my prefered choice of software for any unzipping of files on the PC as it offers the best options - Mike |
Posted: Sun Mar 08, 2009 6:52 pm Post subject: |
tomcat76 wrote: | Mullet wrote: | Download the trial version of WinRAR if its worth pursuing. |
Does it do Cab files, I have winrar but it's a fairly old version? |
I may have made a mistake, the default compression is .rar and I cannot see how to change that other than change the file extension which will probably work.
Try Cab File Maker 2.0 instead. Its free.
Sorry if I have wasted your time |
Posted: Sun Mar 08, 2009 7:37 pm Post subject: |
Once you have de-compressed the download using WinRar why do you need to re-compile it? Extract the files to a known loaction on the PC then copy them straight to the device using Windows Explorer, or extract the files directly to the TomTom device - Mike |
Posted: Sun Mar 08, 2009 8:52 pm Post subject: |
mikealder wrote: | Once you have de-compressed the download using WinRar why do you need to re-compile it? Extract the files to a known loaction on the PC then copy them straight to the device using Windows Explorer, or extract the files directly to the TomTom device - Mike |
Give me a step by step account and I'll try that, ie do they all go in the same location?
I had a nasty experience once before with an older TT and I certainly don't want to mess this one up.....
Already made a full backup of the TT before you ask using TT Home.
I really want to know what this file is, as I said previous I have filled in a report with TT just waiting on a reply. _________________ Regards Steve :-) |
