Pocket GPS World :: View topic - Toshiba e800 and Road Angel
Slicker
PostPosted: Wed Jun 16, 2004 10:52 am    Post subject: Toshiba e800 and Road Angel Reply with quote
Does anyone know where (if possible) I can get a cable to connect my e800 to my road angel.
Paul
Slicker
PostPosted: Wed Jun 16, 2004 11:39 am    Post subject: Reply with quote
edit:
Just found this on the web http://www.globalpositioningsystems.co.uk/search.php?search=e800
Any idea if it will work?
Pc-Mobile
PostPosted: Wed Jun 16, 2004 4:20 pm    Post subject: Reply with quote
That is for a Haicom and it will not work with Road Angel.
There are 2 possibilities for e800.
1. Get the Toshiba serial cable and add a null modem adapter.
2. Use the Toshiba Host cable plus a USB>serial converter.
So the first option is simpler/cheaper.
Pc-Mobile
http://pc-mobile.net/gps.htm
Slicker
PostPosted: Thu Jun 17, 2004 11:08 am    Post subject: Reply with quote
Thanks for your reply.
I have managed to find a cable with the Toshiba plug on one end and a ps2 plug on the other.
Now. The problem I have is that I am not sure what to set tom tom up as in the gps settings. What com port should I be using. I have the following options.)
Com1
Com3
Com4
USB Cable
Native IR
Bluetooth GPS (even tho I have the Wi-Fi version)
I have activated the output from my angel (I think) and have a hyper terminal tool on my pda that scans com1 but I see no data.
Any help?
Paul
Slicker
PostPosted: Thu Jun 17, 2004 1:18 pm    Post subject: Reply with quote
update.
I know that the gps data is coming out of the road angel. I have a ps2 - serial cable and I used that with hyper terminal on a laptop.
So - I just need either a different cable, or the correct setting on my PDA.
Paul
Pc-Mobile
PostPosted: Thu Jun 17, 2004 2:00 pm    Post subject: Reply with quote
I repeat:
Did you not take this advice?
Pc-Mobile
Slicker
PostPosted: Thu Jun 17, 2004 4:50 pm    Post subject: Reply with quote
so,
I need the toshiba to serial (9 pin female) and then a serial (9 pin male) to ps2 male adaptor
Correct?
Pc-Mobile
PostPosted: Fri Jun 18, 2004 3:35 am    Post subject: Reply with quote
Slicker wrote:
so,
Correct?
But YOU CANNOT GET IT !
Unless you make it yourself.
Pc-Mobile
Slicker
PostPosted: Fri Jun 18, 2004 10:01 am    Post subject: Reply with quote
I have ordered the toshiba serial cable and I have a ps2 to 9pin serail as well..i
Will see how I get on when the toshiba cable arrives
Slicker
PostPosted: Wed Jun 23, 2004 2:11 pm    Post subject: Reply with quote
update:
I have the toshiba serial cable now and the ps2 to serial cable for the angel.
Am just waiting on an enginner making me a 9pin male to male serial then I can give it a go...
Slicker
PostPosted: Thu Jun 24, 2004 11:52 am    Post subject: Reply with quote
It Worked!! :D
22.043 (17 Apr 24)
