Pocket GPS World :: View topic - No Direction arrow in 2D Map mode
asus999
PostPosted: Mon Mar 02, 2009 5:53 am    Post subject: No Direction arrow in 2D Map mode Reply with quote
Hi can anyone help me with this, I am using the latest software iGO8 PNA Version 8.3.2.64873 dated 13th November 2008. and the lates iGO8 Ultra 6.0.1.2 Skins..
My problem is, when I view the map in 2D mode, I don't get a direction arrow, or car bmp... everything else works. When I switch to 3D mode, I then get the blue direction arrow.. any way to fix this..
I would like to add the direction arrow or even better, add a car bmp instead of the arrow when using the map in 2D mode..
I am using a generic GPS device.
If I switch to other skins, the directions arrows work as normal.. my problem only seems to be with the igo8 ultra skins..
any help would be appreciated..
linknet
PostPosted: Mon Mar 02, 2009 12:37 pm    Post subject: Re: No Direction arrow in 2D Map mode Reply with quote
asus999 wrote:
Hi can anyone help me with this, I am using the latest software iGO8 PNA Version 8.3.2.64873 dated 13th November 2008. and the lates iGO8 Ultra 6.0.12 Skins..
There's nothing in the Ultra Skin to affect the direction arrow, probably one of the other skins you have installed has disabled it in the saved settings.
Try deleting all of the files, not folders, in the "save" folder after backing them up of course. That should clear out any previous settings.
If that doesn't work check the sys.txt file on your device, and the one on the SD Card, for non-standard settings.
linknet
asus999
PostPosted: Mon Mar 02, 2009 2:33 pm    Post subject: Reply with quote
Thanks for the quick response.. I will try it and post back.
asus999
PostPosted: Mon Mar 02, 2009 7:29 pm    Post subject: Reply with quote
Thanks for your help Linknet. Problem is now fixed. I had to remove the following from the sys.txt file:
3d_scale_carmodel=1
3dcarsizemin=30
3dcarsizemax=40
3dcarsizemul=20
3d_max_tiltlevel=9000
once I did that.. the Direction arrow came back..
Any idea how I can replace the direction arrow with a car bmp?.. I'll search around but any help would be appreciated.
linknet
PostPosted: Mon Mar 02, 2009 8:46 pm    Post subject: Reply with quote
asus999 wrote:
Any idea how I can replace the direction arrow with a car bmp.
My views on using model cars for navigation are totally unprintable, so the polite answer is simply "I'm afraid not". Laughing Laughing
linknet
asus999
PostPosted: Mon Mar 02, 2009 10:37 pm    Post subject: Reply with quote
linknet
thats Kewl.. no worries..
22.043 (17 Apr 24)
