Pocket GPS World :: View topic - Splash screen size?
Splash screen size?
fishingdobbie
PostPosted: Mon Dec 15, 2008 11:46 am    Post subject: Splash screen size? Reply with quote
Just downloaded a widescreen nissan splash screen from tomtom,saved it as a 24bit bmp and loaded it where the others are on my go 530. Turned the unit on and the nissan screen is there, but very small in the centre. The pixal size is 100x57 I take it it wants resizing, what size do you use for the go 530. thanks Bert
Just found out that the screens already on the go530 are 480x272 I will try that
fishingdobbie
PostPosted: Mon Dec 15, 2008 12:32 pm    Post subject: Reply with quote
I noticed the splash screens that were already on the go530 were jpeg, so I downloaded as a jpeg changed the size to 480x274 and it fits ok now, although the resilution seems crap!
Daggers
PostPosted: Mon Dec 15, 2008 2:10 pm    Post subject: Reply with quote
The thumbnail picture on the TomTom site is 100x57. However, if you click on it, a larger version opens on a separate page. THIS is the one you want to download, not the thumbail.
fishingdobbie
PostPosted: Mon Dec 15, 2008 3:50 pm    Post subject: Reply with quote
Thanks for that now sorted, I think it through me because in the instructions it said save as a bmp, cheers
PostPosted: Mon Dec 15, 2008 4:01 pm    Post subject: Reply with quote
The default startup and shutdown images on every TomTom I have ever had, have been .bmp files NOT .jpgs
If you are seeing bad resolution, I suggest you try resaving our image from scratch as a .bmp
The default names for a widescreen model are
(same names for a small screen model but without the "w")
480x272 for widescreen
320x240 for normal
fishingdobbie
PostPosted: Mon Dec 15, 2008 4:33 pm    Post subject: Reply with quote
320x240 for normal
Thanks for your reply,when you connect to the pc and look at my go530 through explorer the splash screens are in a folder called photos and they are all jpeg. I down loaded the larger image as suggested above, and it is showing as a bmp in the same folder, now the res is fine, bert
dhn
PostPosted: Mon Dec 15, 2008 4:40 pm    Post subject: Reply with quote
When you go to Start Up Preferences, the second page gives you an option to change your current startup graphic. It goes to the 'photos' folder and you can scroll through the various .jpg's found there.
When you slect one, TT converts the .jpg to .bmp, overwrites your current splash(w).bmp in the root and, as a consequence, puts the selected one in its place.
I do not believe there is any function in the firmware to change your shutdown image; that's a bit trickier to accomplish.
PostPosted: Tue Dec 16, 2008 4:00 pm    Post subject: Reply with quote
Ah yes there's a new feature to change the spashscreen in the menu, isn't there. Damn clever these Dutch!
But anyway, you can still do it the old fashioned way and simply add the .bmp.
[/quote]I do not believe there is any function in the firmware to change your shutdown image; that's a bit trickier to accomplish.[/quote]
If it doesn't have a "suspendw.bmp" then just add your picture and call it "antitheftw.bmp" and make sure "warn not to leave device in car" is selected in the safety preferences menus
dhn
PostPosted: Tue Dec 16, 2008 7:34 pm    Post subject: Reply with quote
Yep........your last paragraph (about creating the shutdown screen) is what I was referring to as 'trickier'. Not quite as seamless as making the startup image.
Calomax
PostPosted: Sat Sep 08, 2012 8:10 pm    Post subject: Reply with quote
I've tried to use a photo as a new splash screen. I've cropped it and resized it to 480 X 272 pixels and it's a bmp file with a bit depth of 24.
I have extensions showing and definitely have only one bmp extension.
Its in the root of the device with the other splash screens but when I change its name to splashw.bmp, I just get a grey screen, although the others work fine when they have the same name.
TT Go Essential
PostPosted: Sat Sep 08, 2012 8:36 pm    Post subject: Reply with quote
Can you post it up somewhere and link to it here, for someone to have a look at? (or email it to me).
Or... one way I've used in similar weird circumstances is to open one of the ones that DOES work in your paint prog. and then copy and paste your desired image over the top of it.
That way it should get saved with the original properties of the one that did work.
"Settling in nicely" ;-)
Calomax
PostPosted: Sat Sep 08, 2012 8:50 pm    Post subject: Reply with quote
Andy, you are a genius, that worked perfectly.
TT Go Essential
PostPosted: Mon Sep 10, 2012 2:30 pm    Post subject: Reply with quote
Cool!
But I bet it still niggles that you can't see what was wrong in the first place! Laughing
Calomax
PostPosted: Mon Sep 10, 2012 6:19 pm    Post subject: Reply with quote
Andy_P wrote:
Cool!
It does but at least I have my grandchildren on my splash screen Guinness
TT Go Essential
22.034 (27 Mar 24)
