Pocket GPS World :: View topic - route 66
route 66
bigmikeno1
PostPosted: Sat Dec 13, 2008 5:12 pm    Post subject: route 66 Reply with quote
hi i have a route 66 sat nav from china which i am pleased with and it came with software to update camera locations which worked fine but now it tells me to update drivers but don't know how or where to look for new drivers and would'nt be able to install even if i found them a bit beyond my capabillities me thinks any help appreciated thanks mike
PostPosted: Sat Dec 13, 2008 6:32 pm    Post subject: Reply with quote
Firstly I have moved this thread to the Route 66 forum section as its more applicable to the problem.
Does your device still work OK? - if so I would leave it well alone, the only reason to update the application would be to use updated maps which I am not too sure are available.
If the update were to take you from Route 66 version 7 to version 8 then you wouldn't be very happy at all as this application is as good as useless IMHO - Mike
bigmikeno1
PostPosted: Sat Dec 13, 2008 8:51 pm    Post subject: Reply with quote
thanks for the reply the sat nav is one of my fav's it always seem to get you there i have a little garmin 330i street pilot screen to small plus a pioneer avic-s1 good but no speed camera alerts this has some camera alerts but i can not use the updater which was already loaded on the card sometimes it says not attached cannot be found when there it is connected via usb cable it always used to work when it was in mass storage mode as opposed to active sync i have recently changed to a laptop with vista ultimate and wonder if it is compatible with the sat nav sometimes when it stops part way through it says app crash stopped working very frustrating i think the mapping is navteq if thats any help thanks mike
PostPosted: Sat Dec 13, 2008 8:54 pm    Post subject: Reply with quote
What exactly are you trying to update? if its the speed cameras then you should be able to do this via the USB cable and Windows Mobile Device Manager on your Vista PC.
If you are trying to update anything else on the device I would have to ask why? - Mike
bigmikeno1
PostPosted: Sat Dec 13, 2008 9:06 pm    Post subject: Reply with quote
thanks i am trying to update new camera locations plus poi's to keep it current i did'nt know i had a mobile device manager all i usually do is connect direct via usb not to good with computers thanks by the way my name is mike aldcroft not amillion miles from yours will try to find device manager in the meantime
PostPosted: Sat Dec 13, 2008 9:16 pm    Post subject: Reply with quote
You should find the application in Start/ Programs/ Windows Mobile Device Manager (the icon is a green round ball) - This replaces the old Active Sync so you should be able to see the contents of the device using this - Mike
