Pocket GPS World :: View topic - MM on PPC is not moving the map as i move
matrix1
PostPosted: Mon Sep 29, 2008 10:04 pm    Post subject: MM on PPC is not moving the map as i move Reply with quote
Hi All
I have an SPV M600 with region 9 installed, i am using a Holox bluetooth unit. all is fine, i get the target symbol and when i walk i also get the red line of travel. The problem is i can walk off screen - as i walk the map does not track my movements, i need to manually move the map to keep the target on screen. Is this correct? or do i need to do something to correct this.
rothers
PostPosted: Mon Sep 29, 2008 10:17 pm    Post subject: Reply with quote
Have you activated the "padlock" icon which keeps the GPS fix centred on the screen ?
Neil
At the bottom edge of the screen is a padlock symbol, try tapping that to lock your present position to the map center - Mike
matrix1
PostPosted: Tue Sep 30, 2008 5:44 am    Post subject: Reply with quote
thanks for the prompt replies
I had talked myself out of using the lock icon, i had it down to something in the set up or the bluetooth unit. Embarassed
I'll try not to ask anymore daft questions, but i cannot promise.
22.043 (17 Apr 24)
