Pocket GPS World :: View topic - pois in pc navigator 7
iwol
PostPosted: Thu Jul 10, 2008 7:21 pm    Post subject: pois in pc navigator 7 Reply with quote
hi does anyone know how to add pois into pc navigator 7,where do they go and what format please
PostPosted: Thu Jul 10, 2008 8:47 pm    Post subject: Reply with quote
Can you explain in more detail the actual software you are trying to use, quite a number of different nav software providers have version 7 software, and also the name "Navigator" - ike
iwol
PostPosted: Thu Jul 10, 2008 11:36 pm    Post subject: Reply with quote
hi its mapfactor/directions 7.1 thanks,think they are mef/ttr whatever they are
alix776
PostPosted: Fri Jul 11, 2008 8:20 am    Post subject: Reply with quote
they are in custom format youd ned to get the pois in xml format and then put them throught the poi loader that is on the dvd that came with your application and then copy the file that the poi loader produced to your device
device Lumia 950 xl
mikeharris
PostPosted: Thu Jul 24, 2008 12:41 pm    Post subject: Reply with quote
You use the supplied mapexplorer utility to import pois.
This might help?
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=64011
Mike
watchstone
PostPosted: Sat Aug 02, 2008 9:11 pm    Post subject: Reply with quote
I'm obviously mising something somewhere.
I'm using PC Navigator 7.
Importing POI's into Map Explorer is not the problem. I am unable to export from there to Navigator 7
There does not appear tp be any form of link between the two programmes.
Also in the settings page of Navigator 7 the "imported data" button is non-operational
21.014 (25 Jan 23)
