Pocket GPS World :: View topic - Nuvi 250 doesn't accept spoken camera alerts
farcrygamer
PostPosted: Wed Apr 02, 2008 10:59 am    Post subject: Nuvi 250 doesn't accept spoken camera alerts Reply with quote
Hi guys and gals,
I recently bought a nuvi 250 and i seam to be a bit unlucky with it. First there was a problem with car charger and now a bit different problem.
I tried to load camera database together with corresponding spoken alerts in wav format.
Poiloader starts fine but at the and it says that the audio files are not in required format.
Then i tried the same with mp3 format alerts and every seamed fine. No error messages or any other questions.
On the road i noticed that i don't have spoken alerts. It displays the camera warning correctly but it still uses factory set beeps or so.
Is this normal with basic models of nuvi or it's just mine one that gives headache?
Igor
PaulB2005
PostPosted: Wed Apr 02, 2008 11:48 am    Post subject: Reply with quote
This is normal on models that don't have the mp3 player - it seems you need the mp3 player for the spoken alerts to work.
POILoader needs the files in mp3. Wavs where only supported during a test phase and then dropped.
farcrygamer
PostPosted: Wed Apr 02, 2008 11:58 am    Post subject: Reply with quote
Thank you very much Very Happy
You're a true genius for garmins
Is there any trick to install the mp3 player into nuvi 250?
PaulB2005
PostPosted: Wed Apr 02, 2008 12:01 pm    Post subject: Reply with quote
Only to ask Garmin nicely to include it in a Firmware upgrade, I'm afraid. Wink
PhilHornby
PostPosted: Wed Apr 02, 2008 12:14 pm    Post subject: Re: Nuvi 250 doesn't accept spoken camera alerts Reply with quote
Garmin removed the support for .WAV files from POI Loader. However, the earlier version(s) - that did support them - are still available here: http://www.gpsinformation.org/perry/
I can't remember exactly which version supprted .WAVs (I think it was 2.4.0.0 - aka POILoader_2400Beta.exe).
I wouldn't recommend using this version for anything other than this specific task. I don't remember getting a choice of where it was installed, so you might have to copy it somewhere else after installation and then re-install the latest version for general use. There's no problem having multiple versions installed.
People definitely reported the .WAV's working with the Nüvi 2xx series - but I never got the StreetPilot C510 to do the same.
farcrygamer
PostPosted: Wed Apr 02, 2008 5:24 pm    Post subject: Reply with quote
Great news :-_
I'll try my luck this evening when i get home.
Thank you very much
Igor
farcrygamer
PostPosted: Fri Apr 04, 2008 1:17 am    Post subject: Re: Nuvi 250 doesn't accept spoken camera alerts Reply with quote
Works a treat :-)
Thank you so much.
MikeGordon
PostPosted: Sun May 11, 2008 11:58 am    Post subject: Did it work? Camera voice warnings on nüvi 250 Reply with quote
I have just taken a new nüvi 250 for its first run after downloading the GPS World camera database and noticed the lack of voice messages. I found this thread and wondered whether the fix actually works? (The TomToms used OGG files, and before that we had to do a few more fiddly bits and pieces, so are there any WAV files actually created for the Garmin, or does it not work in this fashion.)
Thanks for all the info from everyone in the forum. The manual is so sparse and Garmin's website does not seem to offer any recognition of the nüvi in its drop down lists. It would be nice to know whether you can replace Helga as the voice?, can you get a QWERTY keyboard?, that kind of stuff, but the device does work straight out of the box.
Mike
PaulB2005
PostPosted: Sun May 11, 2008 7:48 pm    Post subject: Reply with quote
If you install and use WebUpdater it'll offer you a few more voices. Not sure about 3rd party ones though.
This was introduced with the 7xx series i'm afraid.
If you download the OGG files from here you'll have to convert them to wav using a suitable piece of software such as Audacity.
Jibee
PostPosted: Sat May 24, 2008 5:51 am    Post subject: Re: Nuvi 250 doesn't accept spoken camera alerts Reply with quote
farcrygamer wrote:
Works a treat :-)
Thank you so much.
Can you explain a little bit more? I tried several times with this version of POILoader but never succeded. I'm sure the produced file contains the wav file as it is bigger but the "Ding" remains.
Which wav format did you use?
Thanks.
PhilHornby
PostPosted: Tue May 27, 2008 12:45 am    Post subject: Re: Nuvi 250 doesn't accept spoken camera alerts Reply with quote
.WAV support has been put back into POI Loader V2.5.2. As well as being undocumented, the change is not complete - Garmin forgot to ship SOX.EXE with it. (POILoader will tell you where it expects to find it.)
Sox is available from http://sourceforge.net/projects/sox/. POILoader uses it to convert your .wav file to 44.1KHz, mono.
moobax
PostPosted: Sat Jun 21, 2008 5:43 pm    Post subject: Re: Nuvi 250 doesn't accept spoken camera alerts Reply with quote
Awesome, thanks for this info! Alerts working nicely on my 255W. I love the contrast between the normal woman and the gruff bloke ("Gatso, thirty").
Feek
PostPosted: Sat Jun 21, 2008 5:55 pm    Post subject: Re: Nuvi 250 doesn't accept spoken camera alerts Reply with quote
Heh heh, sounds like that's my set - I've never been called gruff before though Shocked Wink
mort66
PostPosted: Sun Nov 16, 2008 4:01 pm    Post subject: dnx5220 Reply with quote
hi all, can you add the voice alerts to this model ?
PaulB2005
PostPosted: Sun Nov 16, 2008 4:02 pm    Post subject: Reply with quote
The Kenwood models don't appear to support Voice Alerts either.
22.034 (27 Mar 24)
