Pocket GPS World :: View topic - Navigating to coordinates?
farwellbooth
PostPosted: Mon Apr 19, 2004 8:03 am    Post subject: Navigating to coordinates? Reply with quote
If if add a Mark can I at least get a direction and distance from my current position?
PostPosted: Mon Apr 19, 2004 8:30 am    Post subject: Reply with quote
Certainly, mark the location then right click it, select Goto Mark and you will get two windows, one contains distance to waypoint, direction, speed and eta and the other window has a pointer arrow.
farwellbooth
PostPosted: Mon Apr 19, 2004 7:41 pm    Post subject: Reply with quote
thanks. I didn't have a fix therefore the "Goto Mark" wasn't bold/selectable.
Instead of adding a mark on the map is there another place where I can input coordinates and have the locatin appear? Versus scrolling/searching for the coords. and then adding a mark. thanks
PostPosted: Mon Apr 19, 2004 8:11 pm    Post subject: Reply with quote
The only way I know of is to create a 'Mark' and double click it to view the overlay properties. Then manually edit the position coords and click close. This creates a new Mark with those cordinates.
It's a bit of a bodge but it works and saves you having to find the actual Lat/Lon manually Smile
22.034 (27 Mar 24)
