Posted: Mon Oct 15, 2007 9:52 pm Post subject: TT720 losing 'Warn when near' camera settings
I downloaded the pgpsw speed zoned camera database and ogg files a week ago. I set up the 'Warn when near' distances and sound effects, and did a route demo to check that the spoken warnings were working.
Today I passed speed cameras while using the device for the first time, and got no warnings. When I got home I did the route demo again without getting any warnings, and when I checked the settings, found the distances had all reverted to the 300 yard default setting, so presumably the sound effect setting had also been lost.
As far as I can remember all I have done since setting the warnings up is to install some pgpsw POIs, and connect to Home 1.6 to upload and download map and POI corrections.
I'd be very grateful if anyone can suggest why this might have happened and how I can avoid it happening again. I have fewer than 100 ov2 files. _________________ Anita
TomTom VIA 135 - App 12.075
UK map 1125.12264
Samsung Galaxy S21
Posted: Tue Oct 16, 2007 12:30 am Post subject: Re: TT720 losing 'Warn when near' camera settings
Can't help with the loss of warnings, never had that problem but others have also reported the same problem.
As to having fewer than 100 .ov2 files you need to check the map folder as you said you have downloaded map and POI corrections, this can put anything up to 60 .ov2 files into the map folder. They will be in the form of CA****.ov2 and PA****.ov2, in fact just checking mine I have a total of 66 of them. This leaves me with only 34 available for the PGPSW speed related .ov2's and any others.
If you go over the 100 total then it will be the PGPSW and any others you install that wont show up on the Go 720 but there is no way of knowing which of the ov2 files from PGPSW or you own won't show up. _________________ Graham.
Map: Europe V910.4892
Nokia 925 Windows 8
Posted: Tue Oct 16, 2007 11:17 am Post subject: Re: TT720 losing 'Warn when near' camera settings
Thanks, Graham.
I did search the forum before posting and didn't find any previous references to the problem, but it's sometimes difficult to hit on the right search terms.
Andy_P2002 had pointed out that the CAxxxx.ov2 & PAxxxx.ov2 files downloaded through Mapshare were included in the POI count, and I deleted them and have reduced the categories I accept during updates, so I'm well under the 100. But it's always worth reminding people!
I don't think it would have been the number of POIs causing the problem anyway, as they were all available to navigate to, but in every case when I entered the 'Warn when near' facility I didn't get the 'Remove warning?' screen and all distances had reverted to 300 yards.
Can anyone else suggest a cause and cure? _________________ Anita
UK map 1125.12264
Samsung Galaxy S21
Posted: Tue Oct 16, 2007 1:45 pm Post subject: Re: TT720 losing 'Warn when near' camera settings
As to the cause, don't know, but to cure it you will need to go to Manage POI, add POI, and re do all your POI's again. all your POI's are there but it has lost it's warning settings so you need to go through them all again. If you are using the .OOG files it only takes a few minutes.
Set your warning distance, then the type of warning, I use the first option Full spoken warnings, then tick the warn only if POI is on route. Repeat for each one and you will have them all back again. _________________ Graham.
Nokia 925 Windows 8
It also happened out of the blue to my 520 with the zoned cameras too. What a pain I had to re enable the alerts for each camera & speed type. Is this another gremlin
Joined: Jul 22, 2006 Posts: 274 Location: North Wales
Posted: Tue Oct 16, 2007 5:08 pm Post subject:
A few of us (including me) have repeatedley suffered from this issue where speed cam warnings are lost. It's a real pain, as far as I'm aware the cause is yet to be identified. I reported it to tomtom...only to be fobbed off.
Posted: Tue Oct 16, 2007 6:49 pm Post subject:
Some have said that it happens at some point while connected to Home (either when downloading Mapshare updates or when using the virtual machine on screen).
However when it first did it to me (twice), I was on holiday in Scotland and never connected it to a PC at all. So it is still a mystery quite what triggers it to forget the warn when near settings.
It's done it to me probably 5 times now....
Posted: Tue Oct 16, 2007 7:09 pm Post subject: Re: TT720 losing 'Warn when near' camera settings
Thanks, Graham. I know how to get the warnings back, but I shouldn't have to do it! And I didn't realise they weren't working until I was on the M25, where it's so easy for your speed to creep up that the camera warnings are particularly valuable.
It means I shall have to check them every time I use the device to make sure they haven't lost the settings again.
Andy, thanks for your input. I wondered if it had anything to do with Home/Mapshare, and was going to avoid it for a while and see what happens, but from your experience that doesn't seem to be the cause.
Thanks istinson & pete1336 too. I guess I'll just add to the reports to TomTom and hope they sort it out soon. Well, I always was an optimist! _________________ Anita
UK map 1125.12264
Samsung Galaxy S21
