Newsletter
Pocket GPS World :: View topic - Simulated Input
Simulated Input
Spill
PostPosted: Mon Feb 19, 2007 4:02 pm    Post subject: Simulated Input Reply with quote
Hi . Everything seems to be working ok now with my iPAQ rx5720 & MMap, but why do I get 'Simulated Input' message on the Info button. I've read up quite a lot about GPS but haven't come across this term.Regards. Spill.
PostPosted: Mon Feb 19, 2007 5:04 pm    Post subject: Reply with quote
I suspect this is a license related problem or your GPS settings are wrong on the PDA. On the PDA if you select Menu/ GPS/ Satellites does the unit actually display any GPS information?
If not try Menu/ GPS/ Set-up and what options are listed in the window - Mike
Spill
PostPosted: Mon Feb 19, 2007 5:18 pm    Post subject: Reply with quote
HI Mike. Yes if I go GPS/satellites I get a window into which gradualy the satellites appear, I have done a 4 mile walk and the position indicated was very good
PostPosted: Mon Feb 19, 2007 5:23 pm    Post subject: Reply with quote
If its working and showing the correct position on screen I would simply ignore what it is saying - never seen that message before on any of my units - Mike
dave_a
PostPosted: Mon Feb 19, 2007 10:58 pm    Post subject: Reply with quote
Hi Spill,
The error rang a bell being such an unusual one and sure enough it looks like a few other users have seen it, have a look at:
http://www.memory-map.co.uk/board/index.php?act=Search&CODE=show&searchid=8a157cd3d23c84094b6b6cb6ed68974e&search_in=posts&result_type=topics&highlite=simulated+and+input
Spill
PostPosted: Tue Feb 20, 2007 7:45 pm    Post subject: Reply with quote
Hi Dave.
Right, I've tried all the settings recommended there and get back to (Can't open port com),so I think I'll just ignore the (Simulated Input) message like Mike suggests.I now have set to.
GPS Program Port----Com 7
GPS Hardware Port---Com 1 Baud Rate4800
Manufacture NMEA
Port Com 7 Baud 4800.
Manage GPS Auto (Ticked). Thanks for your time & INPUT. and thanks again to Mike.Regards .Spill
20.093 (21 Sep 22)
Terms & Privacy
