Pocket GPS World :: View topic - 12 Volt FM Amplifier
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Traffic Message Channel (TMC)
RichDem
PostPosted: Wed Jan 24, 2007 5:09 pm    Post subject: 12 Volt FM Amplifier Reply with quote
Does anyone know where I can pick up a 12 volt fm amplifier to boost the in coming FM signal to my TMC receiver?
Regards
If it ain't broke then fiddle with it until it is!
vicky
PostPosted: Wed Jan 24, 2007 6:14 pm    Post subject: Reply with quote
Halfords do an amplified antenna for £9.99 with a preamp in it, which be easily removed and used with a TMC unit.
Above is the antenna,
Below the Preamp unit removed from it to be wired into TMC
http://homepage.ntlworld.com/flashyphotos/ant2.JPG
Below - The Preamp unit added inline between standard car antenna and splitter for radion / tmc unit
Hope that helps.
vicky
PostPosted: Wed Jan 24, 2007 6:18 pm    Post subject: Reply with quote
Sorry, I forgot the image tags on the second picture! and as there is no edit feture, I have added it again below
Below - Preamp unit removed from Ant for install.
swing
PostPosted: Wed Jan 24, 2007 7:15 pm    Post subject: Reply with quote
Can you show exactly how it's wired up, as it's not clear from the photos exactly what you've done to connect it all together...
vicky
PostPosted: Wed Jan 24, 2007 9:08 pm    Post subject: Reply with quote
Its all sealed up behind the dash now
But basically
You crack open the antenna and remove the PCB.
The PCB Has the following Wires,
Red +12v
Black - Antenna Core
Braid - Antenna Ground
Red Goes to a +12v source (I spliced it into my radios power supply lead)
Black goes to the core of your antenna and the TMC unit antenna (Depends on the TMC you are using). if its the Garmin one you would connect it to long black antenna cord, if its the TomTom one you connect it to the pad furthest from the wires on the PCB.. There is a thread in the TomTom Go section that details this in much greater detail.
The Braid goes to the antenna screen
Then if you are connecting the TMC and your car raidio you just need an antenna splitter to split the signal
Have a look at this thread
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=50386
There is a lot of info there buried in the long thread.
And This may also help
http://www.pocketgpspoi.com/downloads/How_To_Modify_Your_TomTom_TMC_Receiver.pdf
philpugh
PostPosted: Thu Feb 08, 2007 4:22 pm    Post subject: Reply with quote
vicky,
Do you have a part number for the Halfords antenna pls?
Phil
PostPosted: Thu Feb 08, 2007 5:14 pm    Post subject: Reply with quote
Phil, Have a look at This page which contains additional pictures and the part number - Mike
mwfox
PostPosted: Thu Feb 08, 2007 6:46 pm    Post subject: Reply with quote
If you like soldering electronic kits you can get a 12V FM amplifier kit from http://www.rapidonline.com/ code 70-4092. Comes with a metal case.
philpugh
PostPosted: Fri Feb 09, 2007 2:50 pm    Post subject: Reply with quote
I have two options as see it.
I can tap into the existing car aerial, which being a VW already has a booster amplifier in it. I'm used to fiddling with these (long time VW owner) but I liked the look of the separate Hafords antenna as a dedicated unit - probably easier to wire in as I already have quite a bit of stuff tucked in behind the radio!
However the item number in the pictures (thanks mikealder) doesn't reveal any results on the Halford's web site. Confused
Phil
PostPosted: Fri Feb 09, 2007 3:15 pm    Post subject: Reply with quote
The Hafords web site does leave a little to be desired! - if you go to the store then look for the section for Radios/ CD's etc (well you can often hear where it is from the door) these aerials can be found on the shelf. Its actual label is:
"halfords Electronic Glass Mount"
* Suitable for most cars
* Self Adhesive mount
* 2500mm Cable
* Signal amplifier
I think its only the amplifier part that viky actually used with the input fed from the existing car aerial (which will be considerably better than the halfords unit) - I use an amplified external aerial to great effect with my RDS unit - Mike
DRP
PostPosted: Fri Feb 16, 2007 1:22 am    Post subject: Reply with quote
Hi all
Have a look at my posts on 5xx. I may be talking a load of bull but it dose
work with CB’s
Regards
DRP
Sharing information is the key to a better understanding
Mio M400 WEU, N60I, T1, 2x B2, iCN 510 & lots more
m623d
PostPosted: Fri Feb 16, 2007 10:08 am    Post subject: Reply with quote
A link would be good! which post are you refering to?
Garmin Emap, Ipaq 2210 with TomTom Navigator 5, TomTom One, Pioneer AVIC-X1R, TomTom 910 (stolen). TomTom 520, TomTom 6100 (Faulty, replaced under warranty), Currently got a TomTom 6200
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Traffic Message Channel (TMC) All times are GMT + 1 Hour
22.034 (27 Mar 24)
