alanparky Occasional Visitor
smspeedy Occasional Visitor
Posted: Mon Sep 18, 2006 11:22 pm Post subject: |
I've just downloaded it and installed it.No issues so far,i'll give it a good test on the road tomorrow.
Steve |
mussey1 Regular Visitor
Posted: Tue Sep 19, 2006 2:19 am Post subject: |
Anyone know what thre route calculation issue is??
Does this mean it will stay on main roads??
Mussey1. |
zogman Frequent Visitor
Joined: Sep 05, 2005 Posts: 1417 Location: swindon uk
Posted: Tue Sep 19, 2006 10:06 am Post subject: |
i was wondering the same thing mussey... _________________ *************************** |
trevf Regular Visitor
Posted: Tue Sep 19, 2006 12:15 pm Post subject: |
zogman wrote: | i was wondering the same thing mussey... | No idea. I have upgraded and everything seems to be back to 2.7 with advanced turning instructions... Looks like they have got it sorted. _________________ Garmin i3
Firmware 3.4 |
Rodonn Occasional Visitor
Posted: Tue Sep 19, 2006 1:01 pm Post subject: |
I had the 'moving while standing still' problem which they claim to have fixed. I'll wait for The Usual Suspects to hammer it out before having to waste time going back to 2.7 (cynical? moi? Absolument!) _________________ Garmin StreetPilot i3
maps - v8
f/w - 2.7 with Audio 2.00
GPS Mode - WAAS/EGNOS
Snooper OEM repeater ant. routed to rear parcel.
Snooper Neo S3R user.
Tried - 2.9 (not a good time) |
Posted: Tue Sep 19, 2006 1:52 pm Post subject: |
No problems so far. No white screen, lock ups, 'moving while standing still' or moving in a totally different direction to the one i am going in or continuing down a road when I've turned off it.
Prompts - better
Screen Update - seems faster and smoother.
Auto Zoom - seems better too
Acquire Satellites Times - seems faster
Calculate and Recalculate Route - seems faster
Time to notice gone "off route" - faster
NOTE: I'm upgrading from 2.7 so some of these updates might not be exclusive to the 3.2 update. 2.7 was the latest Firmware is was happy with.....
Only gripe is the alphanumeric scroller appearing when you select a country - how long is the list? I suspect by the time you scroll to W for Wales you could have scrolled to Wales (on the original list) itself in half the time!! |
Posted: Tue Sep 19, 2006 2:18 pm Post subject: |
I've just got back from a good test and have to agree with Paul in the previous post.Nothing negative to report at all
Steve |
Posted: Tue Sep 19, 2006 5:13 pm Post subject: |
Agreed.
In 2d mode redraw rate seems much faster and smother (even better than 2.70).
No white screen either.
Directional arrow seems now to move instantly when turning.
I'll give it a longer test and report back.
Mussey1. |
giltech Occasional Visitor
Posted: Tue Sep 19, 2006 5:16 pm Post subject: |
Can't see any problems with 3.2 (fingers crossed)
Fast re-draw. Driven over a known route and with going against instructions, I found that re-calculating the route was fast. Driving on 3D with WASS
Upgraded from 2.7FW.
Ready poised to go back to 2.7 if any of the other upgrades are anything to go on.
Let's hope they've cracked it this time.
Gil |
sunstrip_steve Regular Visitor
Posted: Tue Sep 19, 2006 9:57 pm Post subject: |
Quote: | Only gripe is the alphanumeric scroller appearing when you select a country - how long is the list? I suspect by the time you scroll to W for Wales you could have scrolled to Wales (on the original list) itself in half the time!! |
That was one of the solved issues!
I'm looking forward to an extensive test at the weekend |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15125 Location: Bradford, West Yorkshire
Posted: Tue Sep 19, 2006 11:41 pm Post subject: |
mussey1 wrote: | Hi,
Mussey1. |
with 3.1 my i3 had a nasty habit of just hanging while calculating the route - only way to get it going again would be to totally power off the i3 (no batt's, no cable) and quickly go to menu to turn off gps before it starts calculating...
hopefully this is the issue they fixed! will be giving some severe testing on friday but will take to work tomorrow for a test ;)
MaFt |
Almahadeus Frequent Visitor
Posted: Wed Sep 20, 2006 12:09 am Post subject: |
Gone from 3.1 to 3.2 today. 3.2 worked perfectly on navigation mode and I could feel the benefits but it had massive (and I mean massive) screen lags on the view map mode. |
Posted: Wed Sep 20, 2006 12:59 am Post subject: |
I have discovered the following problem with 3.2.
Upgraded this afternoon, cleared all but one single POI from custom points. On the way home from work 3D map mode and track up map mode worked flawlessly, with no lag etc.
At home uploaded speed cam POI's and went for drive to test. Massive screen lag in 3D map mode!!!
As soon as I started from my house the directional arrow refused to move, kept having to press back buttton to refresh screen.
Came back home, deleted POI,s, rolled back to 2.70 then reinstalled 3.2, did a hard reset.
Went for further test with no POI's - PERFECT!!!
It appears that the POI's are causing a serious problem in map mode!!
Can anyone else do a similar test and post the results??
Cheers.
Mussey1. |
Posted: Wed Sep 20, 2006 8:34 am Post subject: |
Got loads of POIs and no problems here!!
My point is that the list is so short that whats the point? I can't see what was wrong with the old list. Now each time i select an address i need to scroll to E to select England. Does it REALLY save any one ANY REAL time at all? Even those in the middle of the list (Netherlands etc) |
