Pocket GPS World :: View topic - OSGB 0n Streetpilot III
Hector
PostPosted: Sat Dec 27, 2003 11:48 am    Post subject: OSGB 0n Streetpilot III Reply with quote
ISTR that there was something available to use OSGB on a streetpilot but now cannot find any reference anywhere/ any ideas?
Skippy
PostPosted: Mon Dec 29, 2003 3:11 pm    Post subject: Re: OSGB 0n Streetpilot III Reply with quote
There is a setting on the SP to change this. I can't remember exactly where but you will find a reference to it in the manual. Wink
Press menu twice and take a look through the settings tabs. You probably have WGS84 selected at the moment. Depending on your firmware there may be a grid reference format and a map datum to select or it may set the grid when you change the datum.
Good luck!
Hector
PostPosted: Mon Dec 29, 2003 5:32 pm    Post subject: Reply with quote
It may have been on the earlier ones, its not there on the 3 Sad
Skippy
PostPosted: Mon Dec 29, 2003 9:43 pm    Post subject: Reply with quote
Hmm. It must be there somewhere. Confused
On my GPS-V you press Menu twice then select Setup then go to the Location tab and set the Location Format to "British Grid" and Map Datum to "Ord Srvy GB". I used a friend's SPIII and it had a setting for OSGB, there may be a lot of tabs so you have to keep pressing the rocker pad to the right to get to the Location tab.
Try downloading the manual from http://www.garmin.com/ if you don't already have a copy of it. (Web site seems to be down at the moment though).
Good luck!
Skippy
PostPosted: Mon Dec 29, 2003 10:49 pm    Post subject: Reply with quote
Garmin's website is working again and I had a look through the SPIII manual but I can't see an option for setting the grid anywhere.
I am stumped. Anyone know? 8O
PostPosted: Tue Dec 30, 2003 7:43 am    Post subject: Reply with quote
Skippy, I'm not sure if OSGB is supported on the GPS V, but it is on the SP III.
Why do you want OSGB datum though ? WGS84 works the best, and switching to another datum in the UK will start sending you away from the roads as the MapSource is configured for WGS84.
22.034 (27 Mar 24)
