Pocket GPS World :: View topic - [b]I prefer Route 66 to TT5!![/b]
welshwizard
PostPosted: Tue Jun 20, 2006 8:42 pm    Post subject: [b]I prefer Route 66 to TT5!![/b] Reply with quote
I currently use a Mitac Mio 168 and am generally quite happy with it.
I have recently bought the latest Route 66 and now have that together with TT5 on the Mitac.
Can anyone give me instructions how to completely remove TT5 and free up more memory so that the whole thing speeds up.
Thanks in advance
PostPosted: Tue Jun 20, 2006 8:59 pm    Post subject: Reply with quote
I would sugest the true sure fire method of a hard reset, as this will clear the device of anything loaded, you will have to re-install any other applications and data/ contacts/ phone book etc. but this puts the device back to the "out of the box as new" condition, I.E you will lose everything.
Or a little bit easier might be:-
As your device is WM2003 based you have the option to adjust the bias of the memory from program or storage area, if you need more program memory slide the bar across to minimum for storage thus releasing memory for the programs (Start/ Settings/ System Tab / Memory this might be an easier way to see if more memory speeds the application up before deleting files you no longer need - Mike
welshwizard
PostPosted: Tue Jun 20, 2006 9:06 pm    Post subject: Reply with quote
Thanks Mike, and sorry for the additional posting. I will learn in due course!!
PostPosted: Tue Jun 20, 2006 9:09 pm    Post subject: Reply with quote
No problems, just try the increase in memory first (if possible) assuming this improves the performance of the device either Hard reset the unit to clear all the other rubish that accumulates over time, or post back and I will give specific files/ folders to delete - Mike
22.043 (17 Apr 24)
