Pocket GPS World :: View topic - Loading downloaded map upgrade
LeighB
PostPosted: Thu Apr 27, 2006 8:21 pm    Post subject: Loading downloaded map upgrade Reply with quote
This may be a silly question but ...
I have purchased the latest GB map for TTN5. The "Self extracting" Installation file just seems to try and load Active Sync 4.1 for the nth time, and does nothing else!!
I had a similar problem with the 4.21 upgrade which behaved the same way, but I got round this by downloading the zip file.
Must I do the same with the map? Have I missed something somewhere?
Why does the program not recognise that Active Sync is already installed and perform the upgrade??
Advice appreciated
Leigh
Mio168 Kingston 256SD
TomTomNavigator3 3.07
TomTom Navigator 5
Memory Map 2004 OS 4.4
Checkpoint 2.02
LeighB
PostPosted: Thu Apr 27, 2006 11:44 pm    Post subject: Reply with quote
Hi all,
I decided to download the zip file anyway, what's another 200Mb download between friends.
With that the installation works just fine. Smile
What is the point of the exe file if it does not work?
Just seems to be there to infuriate users Evil or Very Mad
Leigh
TomTom Navigator 5
Checkpoint 2.02
Silav101
PostPosted: Fri Apr 28, 2006 9:49 am    Post subject: Reply with quote
If the TomTom installer launches another program and not the...well...TomTom installer, that means you have another file named setup.exe in the directory where you downloaded the installer to (typically the desktop).
The TomTom Installer launches the other program because it mistakenly sees a valid setup.exe (not knowing it's not the TomTom setup file) and uses that instead of extracting/using its own, correct file.
Workaround is easy: delete the files in the place you downloaded to. This is vastly easier if you download to a separate directory, like C:\Temp\ , and NOT directly to your desktop.
LeighB
PostPosted: Fri Apr 28, 2006 10:49 am    Post subject: Reply with quote
Thanks for the explanation, at least there is a valid explanation for the apparent illogicality of the Tom Tom upgrade!!
I will make sure I do as you suggest in future.
Leigh
TomTom Navigator 5
Checkpoint 2.02
Silav101
PostPosted: Fri Apr 28, 2006 1:10 pm    Post subject: Reply with quote
Haha~ No problem. It was doing that to me, too. It took me literally an hour of going nuts thinking there was something wrong with my system before I looked at the files in the installers. :-)
22.034 (27 Mar 24)
