Joined: 02/09/2003 17:48:57 Posts: 75 Location: United Kingdom
Posted: Sun Oct 12, 2003 3:53 pm Post subject:
I installed 2.07 and it appeared to leave 2.06 on the machine so I had problems using TTN2.
I removed both 2.06 and 2.07 and did a fresh install 2.07. Maybe I shouldn't have done! When I start TTN2 and go into GPS, Status when I select NMEA 38400 and Port 8 and try to click on the square, all I get is a double beep. And now it doesn't work!
Is the 2.07 better than 2.08?
I mean...right now i'm using the 2.06 version becouse i read about the problem with other GPS programand 2.08 ... but with 2.06 i have the power off issue.
If the 2.07 cure my problem i will go for it :-)
