Newsletter
Pocket GPS World :: View topic - tom tom 5 and mm on a mio 168
roadnobler
PostPosted: Wed Feb 08, 2006 12:13 am    Post subject: tom tom 5 and mm on a mio 168 Reply with quote
Im running tt5 on my mio 168.Im looking to run mm along side it bit unsure after reading of some of the problems that you can run into.
Where is the smarties guide mentioned in this forum?
PostPosted: Wed Feb 08, 2006 4:48 pm    Post subject: Reply with quote
If you want to run both at the same time you will need another application to "share" the GPS data between the application, I use Fransons GPS Gate to achieve this, great application, it works fine on my XDAIIs to do exactly what you are wanting TT5 and MM at the same time - Mike
roadnobler
PostPosted: Wed Feb 08, 2006 10:32 pm    Post subject: Reply with quote
thanks for the info.Can you post the link to Fransons gps gate?
have you transfered tom tom on to a seperate sd card, to accomadate mm and tom tom, ie the map data say for two mm park regions as well as tom tom
PostPosted: Wed Feb 08, 2006 10:43 pm    Post subject: Reply with quote
Well you can download a trial version and/ or purchase the product from http://www.handango.com/SoftwareCatalog.jsp?siteId=159&jid=FFFXFB37ECBEAADCF65D92891E397F56&platformId=2&N=96806&Ntk=All&Ntt=Franson
As for the SD card, I have a number of different ones I use from 512MB to 2GB - copying the files from the original TT SD is easy - just make sure you have "show hidden files" ticked in windows file explorer select Tools/ folder options then the view tab to locate this - then use a card reader to copy the whole lot accross to the PC, then with the new higher capacity card installed copy it all back to the new SD. Mike
20.093 (21 Sep 22)
Terms & Privacy
