herc Occasional Visitor
Posted: Wed Dec 28, 2005 1:15 pm Post subject: hide poi |
When I hide poi does this disable speed cameras?
Another quick question I always have to wait around 5 mins before setting off for a satelite fix is this normal?
Thnx in advance |
Oldboy Pocket GPS Moderator
Joined: Dec 08, 2004 Posts: 10641 Location: Suffolk, UK
Posted: Wed Dec 28, 2005 5:24 pm Post subject: |
Not sure what you mean. If you mean Disable them in Enable/Disable then they will still warn you if you have set up Warn When Near.
To be also warned when not on a Route, you have to Untick the Option to Warn Only When On Route.
When you have to wait 5 mins, is this every time? Also is this when moving?
It always takes a longer time to get a fix when moving, and do you have a heat reflecting windscreen? _________________ Richard
peterc10 Frequent Visitor
Posted: Fri Dec 30, 2005 2:24 pm Post subject: |
The "hide POIs" option on the TT does not affect any "warn when near" settings you have set up. So it will still warn you of cameras as long as you have that set up. |
Posted: Tue Jan 03, 2006 11:05 pm Post subject: |
[quote="Oldboy"]Not sure what you mean. If you mean Disable them in Enable/Disable then they will still warn you if you have set up Warn When Near.
Where do you access these options? |
Posted: Tue Jan 03, 2006 11:07 pm Post subject: |
In Change Preferences > Manage POI _________________ Richard
Posted: Wed Jan 04, 2006 10:13 am Post subject: |
thnx very much |
