Pocket GPS World :: View topic - ipaq3955 and bu303USB
PostPosted: Sun Sep 14, 2003 8:04 am    Post subject: ipaq3955 and bu303USB Reply with quote
hi,
recently I bought a BU303 USB gps to use it on my notebook.worked fine!Now I bought the Ipaq 3955( is on it's way to me now)Am wondering how to connect both USB gps and PDA to the battery power of my car...
Unfortunately you can't. You need a true serial mouse with PDA connector to connect it to a PDA. The iPAQ does not have a USB host facility.
What if I buy a carloader no wire on but just with a usb plug-in connection on it's end (seen them on ebay) and a seperate PDA hot-sync cable..plus a usb mini hub.
I could plug the USB mini-hub in the carloader and plug in both the hot-sync cable(usb) and the Gps (usb)
I think in that case both would get the correct voltage...only wondering about the communication between the gps and the PDA
Any idea if that works?
Afraid not. It's not to do with the connection, but the physical support for Serial devices within the device itself. The 1910 would then have to include USB host support direct, which it doesn't. It's a shame, the 1910's are nice and small and great looking.
DavidW
USB host capabilities are rare on Pocket PCs. On current models, I believe USB host capabilities are limited to some Toshibas. Even if you have USB host capabilities, you need Pocket PC drivers for the USB peripheral you wish to connect.
The best option is to buy a serial USB mouse with the right connection to your Pocket PC. That will have the advantage of providing in car power for your Pocket PC as well, so you won't need to buy a separate in-car power supply for your Pocket PC.
As I am not an expert in this field I probably misjudged the specs as indicated in bold:
Operating System - Microsoft Pocket PC 2002
Processor - 400 MHz Intel PXA250 Application Processor
Display Type - Transflective TFT liquid crystal display 65K color (65,536 colors)
Resolution - 240 x 320
Pixel Pitch - .24 mm
Viewable Image Size - 2.26 x 3.02 inches
SDRAM - 64 MB
Flash ROM - 32 MB
Input Method - Handwriting recognition, soft keyboard, character recognition, voice record, inking
Card Slot - SD Expansion Slot, (other available through optional expansion packs)
Wireless Connectivity - Consumer IR and IrDA (115 Kbps)
Speaker & Microphone
Audio Out Jack - 3.5 mm Stereo
Battery - 1400 mAh Lithium Polymer
Dimensions - 5.3" x 3.3" x .6"
Communications Port - Interface with USB / Serial connectivity that connects via serial or USB cable
Pc-Mobile
Yes it has a USB port.
But like almost all PDAs, it is a CLIENT, not HOST.
For 2 USB devices to talk to each other, one must be host and the other client.
PDA is CLIENT, PC is HOST, so they can communicate.
All USB peripherals, like GPS, are CLIENTS. So it can only connect to a HOST.
Physical connection (male/female) has nothing to do with it.
Some PDA specifications do indicate a CLIENT, but most do not even mention it and I think it is acceptable as most users would be confused if it is not explained in the specifications.
Pc-Mobile
http://pc-mobile.net/gps.htm
Thanks all for your solutions/ explanations!
I also mailed the manufacturer of the bu303 who gave me the adress of a firm named Navishop over here in Holland.
The owner offered to trade in the bu303 and send me the br305 with connecting cables(have to add some$50)
Interface BR-305:RS232 interface with PSII connector .
I am on the edge of accepting this offer as I think this will solve all the problems....
rein
22.043 (17 Apr 24)
