Pocket GPS World :: View topic - Spoken POI alerts for TomTom GO, Mobile, PocketPC and Palm
Goto page Previous  1, 2, 3 ... 20, 21, 22 ... 71, 72, 73  Next
ScaredyCat
PostPosted: Sun Jun 19, 2005 10:53 am    Post subject: Reply with quote
Ok, thanks lutz,
lbendlin wrote:
The second bank is required for TTM.
I've modified it and removed the version stuff, now you just select the file and it's up to the user to know which version (4.42/5.0 etc) system it came off. Unchecking the 'Yes, my device is a TTG' checkbox will result in the second bank being set as the target for the sound files.
SC
PostPosted: Sun Jun 19, 2005 1:17 pm    Post subject: Reply with quote
I would recommend that you always fill both banks, the first with 22050 and the second with 16000. You also have to target the Pocket PC, the Palm, and the UIQ, and with this approach you catch them all. And you can remove that checkbox too.
ScaredyCat
PostPosted: Sun Jun 19, 2005 1:53 pm    Post subject: Reply with quote
Both banks are filled regardless of the state of the checkbox, however, only the appropriate bank is *changed* depending on the state of the checkbox.
ie. If bank 1 is being changed then bank 2 just contains the original sounds.
SC
PostPosted: Sun Jun 19, 2005 2:01 pm    Post subject: Reply with quote
ok, let me rephrase. I would recommend you always CHANGE both banks.
8)
KenJ
PostPosted: Sun Jun 19, 2005 8:19 pm    Post subject: Reply with quote
ScaredyCat, I can't seem to get the app working with TTN5 ver 4890 ? Works with eveything else ?
KenJ
PostPosted: Sun Jun 19, 2005 8:24 pm    Post subject: Reply with quote
Version 4890 seems to have 137 modules.
ScaredyCat
PostPosted: Sun Jun 19, 2005 10:07 pm    Post subject: Reply with quote
Hi KenJ,
Ok, I'm assuming you get the error about it being a bad .chk file - is that correct? Can you send me a copy of the data.chk file from the TTN and I'll take a look
SC
shazbot
PostPosted: Mon Jun 20, 2005 11:05 am    Post subject: DATA.CHK file Reply with quote
I dont seem to have a data.chk file on my tomtom go, i can only see DATA01, DATA04, DATA05, DATA, what am i doing wrong?
Jim-Bob
PostPosted: Mon Jun 20, 2005 11:56 am    Post subject: Reply with quote
The data.chk is the DATA file you have. The .chk is the file type.
PostPosted: Mon Jun 20, 2005 2:07 pm    Post subject: Reply with quote
You don't see the .CHK extension with the Pocket File Explorer. Use Resco Explorer or any other tool that doesn't hide extensions.
ScaredyCat
PostPosted: Mon Jun 20, 2005 4:00 pm    Post subject: Reply with quote
Just a quick note,
with the release of 5.2 firmware the app is broken, I noticed that the data.chk file for the TTG have changed in size...
looking at it now...
SC
ScaredyCat
PostPosted: Mon Jun 20, 2005 4:17 pm    Post subject: Reply with quote
New version released.
Please be aware this version treats you like an adult. If it doesn't recognise the number of modules it will tell you, but it WILL give you the option to continue (or cancel).
http://www.automated.it/ttg-poipatcher.html
SC
ScaredyCat
PostPosted: Mon Jun 20, 2005 4:27 pm    Post subject: Reply with quote
Sorry,
just a quick warning...
I seem to have a problem talking to my TTG via the usb cable.
Just installed 5.2 and now I can't talk to it via the usb cable. Just gives a new screen telling me not to remove the cable, then I see the picture of the TomTom and finally it goes into normal operation (navigation mode)
SC
ScaredyCat
PostPosted: Mon Jun 20, 2005 4:30 pm    Post subject: Reply with quote
ok, nm, panic over
Reset fixed it...
although it did try to detect the ttg as a new usb device needing a new driver
SC
ScaredyCat
PostPosted: Mon Jun 20, 2005 4:38 pm    Post subject: Reply with quote
Ok, version 5.2 with poipatcher results in silent sounds for the ones you patch - unpatched seem unaffected.
Researching it atm
SC
Page 21 of 73
22.043 (17 Apr 24)
