Pocket GPS World :: View topic - eTrex Legend Firmware 3.20 Update
PostPosted: Sun Sep 14, 2003 8:04 am    Post subject: eTrex Legend Firmware 3.20 Update Reply with quote
Garmin have released a new firmware revision for their eTrex Legend. Improved features include:-
  • Corrected problem that potentially rounded northing/easting values when entering or editing waypoints in UTM-based grids.
The latest version can be downloaded from Garmin s Website
PegSneggle
Bear in mind that if you have the European version, with the European basemap, you will end up with the American basemap like I just have.
This happens at both Garmin.com and Garmin.co.uk
Beware
Mike Wood
Really ? That doesn't sound good! There must be a way of changing the basemap back to UK.
PegSneggle
Tail between the legs on this one.
Today I removed the map segments I downloaded from Metroguide and discovered that the original European basemap still existed underneath.
I was convinced it had disappeared after upgrading the unit's firmware. Following this upgrade I switched the unit on and there appeared a map of the United States and Canada.
Mike Wood
AIUI the basemap is in ROM and cannot be physically overwritten by a firmware update, a pity as many have asked how to change the Americas basemap to the Atlantic one!
james merrix
will the european masource data work on top of a unit with an american basemap, if so is this the case ofr all garmin products
jmerrix
James,
It will and it is the case for all Garmin products that are map capable.
james merrix
thanks alot
jmerrix
22.043 (17 Apr 24)
