quincemeister Occasional Visitor
Posted: Tue Oct 09, 2007 8:32 pm Post subject: tomtom 700 glitch |
i have a go 700 and when i switched car lights on screen went dim when speaking radio muted .now all i have done is changed the set of maps and even with the preferences checked it will not dim lights or mute radio any help would be more than welcome as i am completely baffled |
Posted: Tue Oct 09, 2007 8:53 pm Post subject: |
Is your vehicle eqipped with a "Car Connect" device? as this is the only way I can think it would perform the functionality you mention - since updating the unit have you connected the TomTom to the car connect via Bluetooth? and made the setting changes necessary to use the device in the change preferences menu section - Mike |
Posted: Tue Oct 09, 2007 9:11 pm Post subject: tomtom 700 glitch |
no sorry it does not need car connect bluetooth does not need to be connected .it shows in the preferences that it is linked to dim lights but does not happen.would resetting back to factory status cause a problem? |
biggles150 Lifetime Member
Joined: Jan 09, 2006 Posts: 101 Location: Eltham, London
Posted: Tue Oct 09, 2007 9:24 pm Post subject: Re: tomtom 700 glitch |
quincemeister wrote: | no sorry it does not need car connect bluetooth does not need to be connected .it shows in the preferences that it is linked to dim lights but does not happen.would resetting back to factory status cause a problem? |
I fail to see how you can dim your lights with Bluetooth _________________ Go Classic
Application 7.163 (8493/71205)
OS:2328
GB Map v710.1571
Sandisk ultra II 512MB |
Posted: Tue Oct 09, 2007 9:28 pm Post subject: tomtom 700 glitch |
what i meant was the docking preference is showing connected to the lights to dim them the same as the mute the radio which does not happen either [/quote] |
Posted: Tue Oct 09, 2007 9:41 pm Post subject: Re: tomtom 700 glitch |
quincemeister wrote: | what i meant was the docking preference is showing connected to the lights to dim them the same as the mute the radio which does not happen either | [/quote]
But it won't work without car connect. _________________ Go Classic
OS:2328
GB Map v710.1571
Posted: Tue Oct 09, 2007 9:52 pm Post subject: tomtom 700 glitch |
so please tell me where i can find car connect ? as the auto fitter never mentioned anything about this ...........i assumed perhaps wrongly when he connected the parrot system for my mobile phone that he just connected a connection cradle for the tomtom. there was no mention of car connect |
Posted: Tue Oct 09, 2007 10:00 pm Post subject: tomtom 700 glitch |
Posted: Tue Oct 09, 2007 10:19 pm Post subject: |
Have a look Here
Rather expensive me thinks, just to mute your radio and change display to night _________________ Go Classic
OS:2328
GB Map v710.1571
Posted: Tue Oct 09, 2007 10:53 pm Post subject: tomtom 700 glitch |
biggles150 wrote: | Have a look Here
Rather expensive me thinks, just to mute your radio and change display to night |
it was working like that before i downloaded new maps,that is the only thing that has changed so the car connect must be fitted to the car ....i have tried switching bluetooth back on and it still does not link up ..........so i think i may need to call the auto fitter and ask his advice as he fitted it.............but thanks for trying |
Posted: Tue Oct 09, 2007 11:08 pm Post subject: |
Let us know how you get on. _________________ Go Classic
OS:2328
GB Map v710.1571
Posted: Tue Oct 09, 2007 11:21 pm Post subject: |
When you updated the map did you also update the software on the device? - tap the sat strength meter and report back what number is displayed in the version box to the right of the screen, if you have updated the software (or it was updated as a result of a newer map) the bond between your 700 and car connect will have to be re-established - Mike |
Posted: Wed Oct 10, 2007 10:29 pm Post subject: tomtom 700 glitch |
mikealder wrote: | When you updated the map did you also update the software on the device? - tap the sat strength meter and report back what number is displayed in the version box to the right of the screen, if you have updated the software (or it was updated as a result of a newer map) the bond between your 700 and car connect will have to be re-established - Mike |
exactly as you say the software did update but i do not know how to re-establish the bond as the auto fitter that put it in connected it through the car stereo and not bluetooth so it now mystifies me as to do i have to back track the update or is there another way? |
