Pocket GPS World :: View topic - Upgrade from 4.40 to 4.42
HighFreq
PostPosted: Thu Jan 13, 2005 10:58 am    Post subject: Upgrade from 4.40 to 4.42 Reply with quote
I just run the upgrade on my new TTGO but when i go and look for the version it still shows 4.40. Do i have to reset it to load the 4.42 or is it normal to show 4.40 even if i upgraded to 4.42??
regards
rkm_hm
PostPosted: Thu Jan 13, 2005 1:18 pm    Post subject: Re: Upgrade from 4.40 to 4.42 Reply with quote
It sounds like your upgrade wasn't successful for some reason. When it's running 4.42, it says 4.42 not 4.40
What process did you use to upgrade it?
HighFreq
PostPosted: Thu Jan 13, 2005 1:50 pm    Post subject: Reply with quote
I run the application and upgrade the software. It says completed at the end. The only thing i didn't do was connect the unit to a power source because i don't have it with me at the moment.
regards
PostPosted: Thu Jan 13, 2005 2:27 pm    Post subject: Reply with quote
Make sure your SD card is not write locked.
Rename ttsystem and data.chk to something else and then run the setup again.
22.094 (25 Sep 24)
