amdgear Occasional Visitor
Posted: Sun Jan 09, 2005 8:26 pm Post subject: CF GPS Card |
Hi all, im new to all this gps stuff and a little stuck. I bought one of these:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=3730&item=5155568783&rd=1&ssPageName=WDVW The manual which came with it was somewhat brief and I was left confused.
Now, I put the GPS in my Dell Axim x50v and switch it on. I go to Settings > GPS and wait for the app to load. The first screen is greyed out. I click on the GPS tab at the bottom and find the list of GPS devices supported. The manual which came with the GPS device says that the device comes up as CF_CARD-GENERIC and BAUD rate 4800. However, I can not seem to find this card listed in the pull down menu.
When I run Tomtom, it says that "GPS position is unreliable."
Anyone use this card? or know where I can get help? Much appreciated. |
DavidW Pocket GPS Moderator
Posted: Sun Jan 09, 2005 11:03 pm Post subject: |
Seeing as this is apparently a SiRF based receiver, I'd go into the second tab of TomTom GPS, make sure there's no tick in the blue box at the top left (tap the box if there is), then select "TomTom Navigator GPS" in the top box and "CF_CARD_GENERIC" in the bottom box.
If you tap the blue box, then switch back to the first tab, you should see "scrolling dots". At that point, make sure the setup has a good view of the sky, and it should hopefully get a fix within a few minutes.
David |
Posted: Sun Jan 09, 2005 11:58 pm Post subject: |
thanks for the reply david. i did as u said, but the 2nd drop down list only shows the following:
COM3
Native IR
BT UART on COM5
Bluetooth Serial Port COM7
Bluetooth Serial Port COM8
USB Cable
Serial Cable on COM1
Bluetooth GPS
ive tried Com3 and Com1 from the list above. there is no mention of CF Card. |
Posted: Tue Jan 11, 2005 5:53 pm Post subject: |
Which version of TomTom Navigator and TomTom GPS have you got installed?
I'd try 3.07, available from support.tomtom.com in the downloads section - does that help?
David |
cartman Occasional Visitor
Posted: Thu Jan 13, 2005 7:42 pm Post subject: |
Hi amdgear
I'm using the same GPS card as you with TTN v3.07 & ipaq2210 & it works ok. CF_CARD_GENERIC appears as the first item on the drop-down menu, above COM3. Have you tried pressing the reset button on the back ?
If ithe card's not showing on the menu,I doubt it will work - maybe you've been sold a dud ? |
Posted: Fri Jan 14, 2005 7:35 am Post subject: |
cartman wrote: | Hi amdgear
I'm using the same GPS card as you with TTN v3.7 & ipaq2210 & it works ok. CF_CARD_GENERIC appears as the first item on the drop-down menu, above COM3. Have you tried pressing the reset button on the back ?
Posted: Fri Jan 14, 2005 3:39 pm Post subject: |
i am using tt 3.07 yes.
cartman, does your gps card occasionally fail to powerup? its happened 2 times now, the latest being right now i put the card into the cf slot but none of the lights show up. first time this happened, i left it over night and it seemed ok the next morning.
i have hard reset the pda serveral times and reset the gps card (dont think resetting this does much) but generic cf card never shows up on the 2nd pull down menu of the gps app with tomtom.
Posted: Fri Jan 14, 2005 10:10 pm Post subject: |
You asked "does your gps card occasionally fail to powerup?"
No - if I put it in the slot with the PDA off, it switches the
PDA on & it's LED flashes momentarily. It doesn't work then until TTN is on & it's selected from the drop down menu. No problems at all with it. It does sound as though you have a dud ! |
Data359 Occasional Visitor
Posted: Tue Jan 18, 2005 9:47 am Post subject: CF Card GPS |
Hi Guys I have a similar problem I have the same CF card with a IPAQ 3660 running TT 3.07 and GPS 3.07. I have tried the solution above but cannot get TT to accept Tom Tom Navigator GPS and Generic CF Card as a recongised solution (the choices are there in the drop downs) but when selected and then tapping in the check box no tick appears. I can select Tom tom Navigator Wireless GPS and Generic CF Card and this locks in (tick appears in box) However nothing appears on the GPS First page although the lights on the GPS show that it is locked. Using the software supplied with the Unit I can get a fix locked in but nothing in Tom Tom. I have since removed the software that came with the unit. Any ideas would be appreciated. thanks |
StevenGourlay Frequent Visitor
Posted: Tue Jan 18, 2005 1:17 pm Post subject: |
I have used many of the CF GPS receivers and they all default to:
CF_GENERIC
Make sure you don’t have any other GPS drivers install that could be locking the port and turn IR off. _________________ Regards
Steven Gourlay
Bike Pics! Bike Chat! Visit-Ullapool |
Posted: Tue Jan 18, 2005 3:52 pm Post subject: CF Card |
Thanks Steven I will check out what else I have installed and try again. |
Posted: Tue Jan 18, 2005 4:16 pm Post subject: |
Hi Steven tried this but I still cannot activate by selecting Tom Tom Navigator GPS and CF Card Generic - The tick box stays blank.
I have tried a reset, reinstalling the software and upgrades but to no avail. I have switched off infra red and removed any other software or drivers.
Any further suggestions |
Posted: Tue Jan 18, 2005 5:02 pm Post subject: |
Hi Guys problem solved.
Hard Reset the IPAQ - I was only going to use it for Navigation anyway.
Reinstall TT 3.07 and maps
Reinstall Voice
Add expansion pack
Plug in GPS
Select as described and click in check box and hey presto its working.
Thanks for all your assistance Steven.
Will now get to test it on the way home.
Regards
Peter |
